Re: [motm] cool Moe's cool MOTM-800 mod!
2000-09-28 by jwbarlow@aol.com
In a message dated 9/27/2000 11:54:29 AM, daveb@... writes: >I modded my MOTM 800s to have an output LED (yes, Barlow, you were >right, it's cooler than a gate LED.) It glows in brightness corresponding >to >the level of the envelope output. It gives you immediate feedback on what >your envelope generators are doing in the midst of a complex patch, and >helps to troubleshoot when things are not being gated correctly. > >Pix at: >http://www.egroups.com/files/motm/800mod/ > Gosh Moe, I'm honored that you were willing to try my suggestion of the output in addition to your GATE LED (which I also like, nut think that they should also be on the output of the particular device which produces the GATE signal, like a sequencer clock, or keyboard gate and the like). This is just another example of high caliber of debate and quality of intellect that can be found on this great list. And just to continue that respectful level, I'd just like to add: Nanny nanny nanny! I told ya so! I told ya so! HA HA HA HA HA!!!!!! John (I got yer LEDs right here Bradley, nyuk nyuk nyuk) Barlow
