AH low pass vowel sounds patch..
2000-09-17 by revtor@aol.com
JBarlow, and everyone else, The vocal/vowel patch from Ah was saw osc into a lowpass which is being very slightly modulated by a triangle wave tuned three octaves and a fifth above the input wave's frequency. I didn't play too much with the patch, but I found that a little res helps too, and the sounds come from when you manually sweep the cutoff of the filter. A certain thin range of the filter's sweep gives the most "vowelly" sounds, it would be interesting to know what the frequency relationships are. Try this into a hipass or bandpass too...? There it is, ~SteveM
