Korg MS-20 power transformer question for MOTM MS20 owners
2000-09-13 by The Old Crow
OK, I've been informed that the synth-diy list has been down a couple
days.  Perhaps one of the MOTM folks that also have an MS-20 can help with
my question:
  I've decided to rewire the AC line side of my MS-20 to use 115VAC as
opposed to its stock 230VAC (unit was originally in Europe).  Looking at
the transformer, I notice two extra, unused primary-tap wires that have
been sealed up in heatshrink.
  Now, my other Korg gear uses this same style of primary taps to select
the input voltage, so I figured this is also the case for the MS-20.  My
question is, which two wire-colors are used for 115VAC?
  I could measure the winding resistance for each tap, but then I'd have
to take the entire cabinet apart whereas I'm trying to get this done with
just the right-side end cap removed.  Thought I'd ask to see if someone
out there 1) has already done this and can tell me which wire colors, or
2) can take the right-side end cap off their 115V MS-20, look at the
transformer and tell me what the connected wire colors are.  The service
manual doesn't show this.
Crow
Re: [motm] Korg MS-20 power transformer question for MOTM MS20 owners
2000-09-14 by The Old Crow
FYI, I went ahead and took the machine all the way apart and figured out
the rewiring.  The unloaded secondary showed about 42VAC (21VAC to the
center tap).  The primary showed a resistance of 136 Ohms for the original
240VAC configuration.  tinning up the extra primary leads and measuring
about, I got the following:
   yellow     orange     brown      black
     |__15 Ohm__|__80 Ohm__|__41 Ohm__|
     |          |__115VAC__|          |
     |_____________230VAC_____________|
  The 80 Ohm orange-brown pair seemed to be close enough to 1/2 of the 136
Ohm yellow-black pair to test out on my Variac set to 115VAC.  Secondary
showed 42VAC unloaded.  After reassembly, the MS20 seems to be doing fine
on 115VAC off a power strip.
  Now to dig out the Greenlee and punch the rear chassis plate for a
standard power socket and a DIN-5 at some point.
Crow
