Re: [motm] Oakley LFO
2000-08-29 by sikorsky
From: thomas white <djthomaswhite@...> > > Where did you add or put the LFO rate switch in the schematic? I would like > to add this too for when I get my Oakley LFO. Thanks for the info hello all, i'll keep this on the list as a few may be interested: as per the schematic, C18 is 100nF - this gives you roughly 0.2Hz - 25Hz, you need to add a switch then a 1uF capacitor in parallel with C18 to get down to around 0.01Hz i just tack soldered some wire from pad one of C18 to a switch, then to the 1uF cap and back to pad two of C18 with the switch open you get "slow", with the switch closed you get "slower" thanks go out to Tony for helping out on this and other demanding mods i keep wanting to make for instance, we can't get Lumex LEDs here in the UK (please somebody prove me wrong), but we can get LEDs that look similar, only there isn't a bicolour version - so for the LFO i also *had* to go for the classic Korg MS style LFO indicator (stick a reversed 1N4148 in parallel with the LED) cheers paul b
