Litany of Panel lettering/graphic schemes
2000-08-26 by Frank Vanaman
Hey everyone-
Tentochi wrote:
> Nice page Frank.  How did you do your graphics (if you haven't posted it
> before)?  I am still waiting to silk screen my Chaos panels...
Well, there's three different schemes used for the three different
non-MOTM modules!
The Multiple/attenuator was done with the press-on lettering (i.e.,
paint the panel, drop on the lettering (carefully, please) and clear
coat the whole mess afterward. Looks OK, simple and easy to do.
The Roctave Divider is a paper overlay. I used a whole page-sized Avery
peel -n- stick label, printed the graphic on the label page, cut the
page down to the right size, painted the panel black (so that  there
wouldn't be non-painted edges showing), slapped the label on (not
terribly fun to get it right) and then clear coated.   This was mostly
an experiment to see how much of a mess it would be to do-- the graphic
was borrowed from the .JPG of the 800 EG, with new text created in Paint
Shop to attempt to match the 800 text. The registration of the 'input'
and 'output' legends and lines with the jacks is off, but I made the
mistake of not drilling the panel using a first/junk label as a
template. Ooops.
The Oakley ladder filter has a Schaeffer panel...
(http://www.schaeffer-apparatebau.de/ and go to Frontplatten Designer)
with engraved legends on an anodized plate. I did not make this (hah,
well, no, Schaeffer did, silly), but actually bought one of Tony
Allgood's prototypes completely built & operational, with the panel.
Frank
