RE: [motm] stand for sbk pop-up mixer case
2000-07-10 by Tentochi
> No worries--I was able to record anotherOf course you didn't lose your patches! It's an MOTM!!! Incredible patch
> take that was much better, and the only thing that had "severed" was the
> power connection between the two MOTM cases. The connector pulled cleanly,
> and everything is just fine. Phew!
> David.
2000-07-10 by joe.pavone
2000-07-10 by Nathan Hunsicker
>This is my cue to tell you all that my system fell on me yesterday! I have
>it on the top rail of an Ultimate A-Frame--the "arms" fit nicely into the
>SKB case grooves (I have two cases like Joe's). I reached behind my
>patchbay/effects rack to do something, and I must have put pressure on a
>cable or something. I had load tested the damn thing, rocked it, everything.
>But down it came, into my arms and onto all the gear below it. One of the
>cases nicked an end cheek on my 777. Minor blemish, but still...
>Anyway, so there I am, holding the cases up with my arms and holding my
>other gear against the A-frame with my legs. The arms on the two other tiers
>had gone vertical from the pressure of cases falling against the gear on top
>of them, so if I didn't keep my legs there, all the gear would have fallen
>forward and onto the floor. I spent 10 minutes like a rock climber in a
>do-or-die situation: "O.k., I'm going to slide my left pinky a centimeter to
>the right..." I was trying to get the SKB cases gently to the floor without
>dragging everything else (they were all patched up into the other rack) with
>it.
>I finally got everything on the floor gently and carefully adjusted the
>stand and re-positioned everything (correctly this time). The funny thing is
>that my patches were still intact! I had been recording a track immediately
>before this, and I wasn't happy with it so I was going to have another go.
>My SP-12 is losing its internal battery I think, because it often freaks out
>and resets itself. Clearing the memory is the only thing I can do to bring
>it back up to spec. So I would have lost some bizarre sample looping I had
>done as well as a distinct pattern. No worries--I was able to record another
>Take care,
>David.
>> -----Original Message-----
>> From: joe.pavone [mailto:fuzztone@...]
>> Sent: Monday, July 10, 2000 11:49 AM
>> To: motm@egroups.com
>> Subject: [motm] stand for sbk pop-up mixer case
>> For those of you who have your motms in a pop-up mixer case, or
>> if you are thinking about it, check this out....
>><http://www.jpq.com/jpp/motm2/motmqlside50.JPG>http://www.jpq.com/jpp/motm2/motm
>><http://www.jpq.com/jpp/motm2/motmqlfront50.JPG>http://www.jpq.com/jpp/motm2/mot
>> That is a quiklok amp stand model # BS-317 and is a nice way to
>> keep your motm upright withoot popping the top and exposing the guts.
>> ...jp
>> Free Conference Calling with Firetalk!
>> Click Here!
>><http://click.egroups.com/1/5480/6/_/529958/_/963251229/>http://click.egroups.co
2000-07-10 by David Bivins
> ...jp
> Click Here!
> From: Nathan Hunsicker [mailto:nate@...]
> Sent: Monday, July 10, 2000 12:16 PM
> Subject: RE: [motm] stand for sbk pop-up mixer case
> Ultimate makes a 15 rack space bolt on rack frame for their a-frame racks.
> it looks like you could put 2 side by side and have 30 spaces of motm on
> one a-frame tier. A good idea for all the "studio use only" guys. -Nate
> From: Tentochi [mailto:tentochi@...]
> Sent: Monday, July 10, 2000 5:33 AM
> Did you lose all of your patches when you broke the power connection?!?!?
> How dreadful! Did you have your MOTM patches backed up?
> pulled cleanly,
> > David.
> retention even when left unpowered for decades! Screw battery
> replacement!
> --Shemp
> 0% Introductory APR!
> Instant Approval!
> Aria Visa - get yours today.
> http://click.egroups.com/1/6035/6/_/529958/_/963264660/
2000-07-11 by ivancu@aol.com
