VCO calibration nightmare
2000-07-06 by Thomas Hudson
I built two 300's the last two days. When I went to calibrate them,
I knew something was wrong. The 300 I had previously built and
calibrated wasn't tracking correctly, and I couldn't tune the
two new ones, the trimers were all the way to one extreme and
still didn't track.
Then I found the culprits. I had recently built new patch cables
using neutrik connectors. When I pulled these out and used some
older cables everything started working perfectly.
I used a DVM and got a resistance measurement between the tip
and sleeve.
So obviously I don't quite understand how to assemble the
cables correctly using the neutrik connectors. They don't
seem to have a good place to solder (especially the ground
connection), so I assumed the locking action of the cam
pushed the cable down to make the connection.
Anyone else using these connectors? Any tips on how to
assemble them?
Tomy
still didn't track.
and sleeve.
assemble them?
Tomy
