Re: [motm] MOTM DIY
2000-06-28 by alt-mode
Larry, Your module sounds very neat. I can see many uses for it, not just for keyboard CV->VCO. Perhaps you should have a discussion with Paul about making it a MOTM utility module and getting some royalties ;^) Seriously, I'm not likely to build up my own module like this (soldering is not a big deal but the mechanical stuff always gives me problems) but I would be interested in buying a professionally constructed version with the appropriate panel, etc. Eric P.S. I would call it a voltage shifter instead of a pitch shifter... > > This module is a manually controlled pitch shifter. I started to make this > just an octave switch, as I wanted a way to shift octaves and maybe 5ths > between my MOTM oscillators without having to retune them. I just like > having octave switches on an oscillator. BUT, the MOTM-300's pot control > offers more range and I did not want to even THINK about modifying the > greatest oscillator module on the planet. So, my original plan was to make > a module that put out a selection of fixed voltages that could be connected > to one of the FM inputs of the MOTM-300 to provide this feature (real simple > stuff). There was some discussion on the list. However, Ken Tkacs twisted > my arm around my back (a neat trick via e-mail) and told me my plan should > be modified so that the 1 volt/oct voltage keyboard CV connects to my > module, and then my module connects to the MOTM-300 or any 1 volt-oct VCO. > After first dismissing this as too difficult for a guy with a business > degree, I finally admitted Ken was right (like he almost always is BTW), and > adopted his concept for my project. > > The result is a 1U utility module with three rotary switches for interval > selection and six 1/4 jacks (3 CV IN, 3 CV OUT). Each interval switch can > be used separately, or all outputs controlled by the same keyboard CV > (normalled a to b, b, to c). This simple circuit adds the selected voltage > interval to the incoming keyboard CV and that is the output. This first > version has 5 interval shifts up and 5 down. There are three channels of > shift. The interval shift amount is completely "user selectable" by the > fixed resistor selection in a corner or the circuit board (when building). > I was going to use only octaves and 5ths. But along the way with my > experimenting, I found many other useful and interesting harmonics (Thanks > Ken) > > So, you hook your keyboard CV to the input of the module. You hook this > module's CV outputs (3) to the 1-volt-oct inputs of your oscillators and > tune all the oscillators in unison (at the high end of the CV range BTW). > Then you can use the rotary switches to shift the intervals between > oscillators. Of course, one oscillator (your fundamental frequency) does > not need to pass through this module. I have the module constructed and > tuned and it works quite well. > > Version # 2 of this module, will feature only 2 channels of shifting (yes, > we can get by with 3 oscillators per voice). However, it will have MUCH > more shifting capability. It will have 4 rotary switches and 4 jacks (2 CV > IN and 2 CV OUT). The difference is that ANY semitone interval is > selectable. Since each shift channel has 2 switches, one will select > octaves up and one octaves down. The other will select intervals in > semitones +1 through +11. So, no user interval choice will be required when > building. Version # 2 is layed out on paper proto board but will not be > tested and functional for about a month. I am taking a 2 week vacation to > the Washington, Idaho, Montana and Calgary, Canada. So, I will start > constructing it when I get back. > > Obviously, these are simple circuits consisting of resistor voltage dividers > for interval voltages and op amps for DC adding. The trick has been getting > the accuracy in the 1 volt/oct CV. If anyone has any additional interest in > either of these two utility modules, please e-mail me off list. I don't > want to turn the MOTM list into DIY discussion for the many that don't > build. However, since this is created in the MOTM format for use with MOTM, > I wanted to share it with the list. > > Thanks to Ken Tkacs for his inspiration and to Paul for answering the one > hundered stupid Stooge-like questions. > > Larry Hendry > > Disclaimer: I am not a BS/MSEE. I am not a design engineer. This is DIY > learning stuff. My only claims are that: > 1 - I am having fun > 2 - My circuit works very well > 3 - I am buying more MOTM proto boards than anyone else. > > > > __________________________________________________ Do You Yahoo!? Get Yahoo! Mail - Free email you can access from anywhere! http://mail.yahoo.com/
