Re: [motm] ribbon contrller yet again!
2000-06-20 by ivancu@aol.com
In a message dated 6/19/00 9:53:41 PM, jwbarlow@... writes:
<< It's always seemed
to me that the difficult part of building a ribbon was the resistive element
Back in ancient PAIA days (1974?), they had a very crude keyboard that was
made of plastic buttons and spring wire over a conductive plastic strip.
Does anyone have any idea where you can buy a conductive plastic strip like
that?
Ivan
2000-06-20 by davevosh@aol.com
In a message dated 00-06-19 21:53:40 EDT, you write:
 -- this eliminates that part.
 Any thoughts? >>
john,
what about the old idea of using magnetic tape ? has anyone tried that lately
best,
dave v.
In a message dated 00-06-19 23:06:57 EDT, you write:
 that?
ivan,
i had one of these.... my first real synth. ( as opposed to electro-junk. )
think i paid something like $150 for the set of kits.
maybe john s. could suggest a source of the plastic ?
best,
dave
2000-06-20 by jwbarlow@aol.com
In a message dated 6/19/2000 8:16:23 PM, davevosh@... writes:
>lately
I've seen references to this (most recently from Grant Richter on diy) but
I've tried on a couple of different occasions to measure the resistance of a
strip of magnetic tape (two or three different brands) and always found it to
be "infinite." Have you had any luck with tape?
I have had luck getting a reading across a strip of black trash can liner
material (Gene Stopp's idea). It seems to flimsy to make a real ribbon
controller with it.
An idea I had several months ago (I may have already posted it) was to use
that thin "high resistance" insulated wire (like that used in guitar PUs),
and wrap it around a stick to roll your own wire wound resistor. Carefully
sand the top of the insulation off to allow contact with a spring loaded
conductive strip.
JB
In a message dated 00-06-20 00:10:13 EDT, you write:
 conductive strip.
john,
no, i`ve never tried the magnetic tape idea but have seen it referenced
several places. apparently, it does work. never heard the one about trash can
liners - do you mean plain old large, green plastic trash bags ?
the wound rod idea sounds like it could have possibilities......would sort of
end up like a trautonium controller if i understand what i`ve read about
them. in fact, if you haven`t checked it out, there is a lengthy article with
some interesting diagrams about trautoniums on doepfers website.  well worth
a look.
best,
dave v.
