Thar she blows !!! (was Panel Label Adhesive etc)
2000-06-14 by mr sikorsky
hello all
>The next module will probably be the MOTM-200
Voltage-Controlled Pulse
>Divider. Why? Because it's 100%
>designed and tested! It does require new mechanical design (and has 13
>jacks!)
>jacks!)
any more details on this mon
general..?
on a personal note, if i'm having my 101 & 820
shipped together, does this mean i'd now be getting a 200 as
well..?
cheers
paul b
ps in answer to thomas white (i think)
i've used Letraset / Dry Transfer Lettering / there
must be some equivalent in the USA..! (available from graphics supplies, art
supplies & stationers) for labelling then i generally find that three
coats of automotive lacquer is plenty
if there really is a total drought of dry transfer
lettering in the USA, the cheap stuff over here is only around £1
a pack, i'll send some over - you just have to promise to pass it around :-)
meanwhile, off topic again, has anyone in the UK found a source of US
standard three pin ring binders (for MOTM instruction manuals) cos i'll be
buggered if i can find anyone that sells then, i've had to resort to blagging
them from a friend who gets paperwork sent over from
Canada...
