Re: [motm] Bob Moog's Thesis (was Re: SF Modular Meeting)
2000-06-07 by alt-mode
Wasn't it about attenuation through rochelle salt crystals?  I don't recall if the
frequency range was audio or not...  I guess that's what you get when you are doing
a PhD in Physics!
Eric
--- Fred Becker <mach25@...> wrote:
> Correct!  None of us at the meeting got that one.
> At 06:50 AM 6/7/00 -0400, you wrote:
> >In a message dated 00-06-07 01:31:29 EDT, you write:
> ><< What was the subject of
> >  Bob Moog's PHD thesis?  >>
> >something to do with rochelle salt crystals wasn`t it ?
> >best,
> >dave v.
Do You Yahoo!?
Yahoo! Photos -- now, 100 FREE prints!
http://photos.yahoo.com
2000-06-07 by davevosh@aol.com
In a message dated 00-06-07 12:17:17 EDT, you write:
<< Correct!  None of us at the meeting got that one. >>
fred,
wow! all that assembled synth knowledge and no one got it .......... gee,
does that mean i can get a motm cap?  :^)
i remember reading something about moog and his history some time ago and
that tidbit stuck in my mind because in the "dark ages" ( 1970 - 72ish ) when
i was first fooling around with e.m., most of my stuff was radio stuff ( i
had been a ham ) and odd junk that i built or modified not "knowing" that
some crazy stuff wasn`t supposed to work. i used to use old microphones as
"filters" - a carbon mike sounds different from a crystal (rochelle salt)
mike from a dynamic mike and such. so, the bit about his thesis being on
rochelle salt crystals just "resonated" and stuck with me.
and, thinking about it, hi-tech be damned, i miss some of the sounds i used
to get from torturing old bits and pieces......... ( try passing a sustained
sound through a 3 inch tv speaker ( which i used to get by the boxful from
electronics class in high school at the time ) and setting the cone on fire
and recording the sounds through a crystal mike while it totally burns up and
finally vibrates apart  or soldering 4 cheap mikes to a plug to feed the tape
recorder, volume was controlled by spacing the mike from the sound source,
and getting weird intermodulation distortions or.. ....but you get the idea.
sometimes not knowing something was "wrong" was very liberating ! )
best,
dave v.
