Re: [motm] Cabinet styles
2000-06-05 by Paul Wagorn (Worldbid)
hi nate - i made my cabinet with exactly 3/4 of an inch recess. no problem at ALL with knobs, especially if you use the rails, because there is quite a bit of space along the sides.. on the top, there is still plenty of room to get your fingers in there.. -paul http://www.mp3.com/puffboy ----- Original Message -----
From: "Nathan Alan Hunsicker" <nate@...> To: "MOTM Newsgroup" <motm@egroups.com> Sent: Monday, June 05, 2000 10:25 AM Subject: [motm] Cabinet styles > Has anyone mounted their modules in a rack or cabinet with the modules > set back 3/4 of an inch? after reading someone's story of how their > modular fell and broke off some knows and pots I figured I would build > my cabinet with the modules recessed 3/4 of an inch so that if the > cabinet should ever fall over face first, the knobs would be protected > (providing it falls on a flat surface) Not that I make a habit of > dropping my modular, more of a precaution, than a daily use function. > The question I ask, is if anyone has done this, do they have problems > adjusting knobs that are flush up against the top or sides? That is the > only concern I have. If anyone has tried this, i would appreciate > feedback before dedicating a lot of time to this project. Thanks in > advance! -Nate > > ------------------------------------------------------------------------ > Failed tests, classes skipped, forgotten locker combinations. > Remember the good 'ol days > http://click.egroups.com/1/4053/5/_/529958/_/960225836/ > ------------------------------------------------------------------------ > >
