Re: Roland 180
2000-06-01 by Paul Schreiber
YES! Use a home-made "special interface cable". Put a 1/8" plug on one end, and on the other end get 2ea 1K resistors (any value from 1K to 4.7K will work, as long as they are the same). Put resistor #1 in series with the inner conductor and the tip of the 1/4" plug. Put resistor #2 from the tip to ground. This makes a simple 2:1 divider. And it all fits inside the plug casing. Paul S. Proud owner of a 184. yes, it IS a JP-4 CPU board in there! ----- Original Message -----
From: Charles Stella <cstella@...> To: <synth1@...> Sent: Wednesday, May 31, 2000 6:41 PM Subject: Roland 180 > Paul, > > I got the Roland 180 keyboard today. The gate and trigger's > output is +15v. Do I have have to modify this for 800 use? The 800 > manual specifies 0 to +13V. Thanks, Charles. >
