CV Keyboards
2000-05-30 by ivancu@aol.com
2000-05-30 by Nathan Hunsicker
>I know this is somewhat silly, but is anyone out there still making a
>control-voltage keyboard? No, I don't want to use a MIDI keyboard with a
>MIDI-to-CV converter.
>Ivan
2000-05-30 by Dave Bradley
> -----Original Message-----
> From: Nathan Hunsicker [mailto:nate@...]
> Sent: Tuesday, May 30, 2000 11:55 AM
> To: motm@egroups.com
> Subject: Re: [motm] CV Keyboards
> i've been searching for a while now and have found nothing. other than the
> novation basstation keyboard with a tiny keyboard and a cv out (which i
> belive is just a built in midi to cv convertor) I don't know of any in
> production. I have been dreaming of a DIY project consisting of a standard
> keyboard with individual tuning controls for each key (mind you this would
> require expensive resistor chains and 48 pots for a 4 octave keyboard but
> would be a great hit for the microtonality guys. I'd also like to
> include a
> keyboard split to convert the keyboard into 2 seperate 2 octace keyboards
> (i'm not even going to attempt polyphony) The final cost would prob. be
> well over what a decent midi controller and MIDI/CV convertor
> would cost. I
> know this really doesn't help, but it's food for thought. -Nate
> >Ivan
> Failed tests, classes skipped, forgotten locker combinations.
> Remember the good 'ol days
> http://click.egroups.com/1/4053/5/_/529958/_/959705815/
2000-05-30 by skinny bastard
>From: ivancu@...________________________________________________________________________
>Reply-To: motm@egroups.com
>Subject: [motm] CV Keyboards
>Date: Tue, 30 May 2000 12:10:54 EDT
>Ivan
2000-05-30 by Brousseau, Paul E (Paul)
> From: skinny bastard [SMTP:skin_job@...]
> Sent: Tuesday, May 30, 2000 12:50 PM
> I'm working on mine. Pretty limited though.
> Analogue Systems has one that they're going to have available within a
> month
> or two, but expect it to be anywhere from 1500 to 2000.
> month or two, but expect it to be anywhere from 1500 to 2000. >>http://www.analoguesystems.co.uk/rssystems.htm
2000-05-30 by J. Larry Hendry
> From: ivancu@...
> Date: Tuesday, May 30, 2000 11:10 AM
> Ivan
> Find long lost high school friends:
> http://click.egroups.com/1/4056/5/_/529958/_/959703117/
> From: J. Larry Hendry [mailto:jlarryh@...]
> Sent: Tuesday, May 30, 2000 4:39 PM
> OK, I have some comments on this.
> 1. I have a keyboard assembly that is brand new that was manufactured for
> a MicroMoog that has the resistor assemblies already installed
> and ready to
> go. I bought the thing for $25. No, I am not selling it. However, I can
> tell you that the accuracy is not very good. I have compared my MicroMoog
> CV output to the Kenton pro-2000 and the Kenton wins, hands down.
> 2. I don't see what the big deal would be to make a CV keyboard with each
> note tunable. I think if I were doing it, I would use BOTH fixed and
> variable resistance. As I see it (and please jump in there if you
> disagree) the problem with fixed resistors is exact accuracy. The problem
> with variable resistors is stability and cost. And, you would not want to
> connect variable resistors so that tuning one, changes the total
> resistance
> of the string.
> So, I would make my voltage divider with the a fixed resistor and trimmer
> in parallel. Then, this parallel combination would be connected in series
> with as many as I needed for the number of keys I was planning (and maybe
> trimmers on the ends for range). I would plan the voltage at the resistor
> junctions to be about 1/2 way between the voltages I wanted on the keys so
> that the wipers of the trimmers at 50% would be very close. Then each key
> could be individually tuned without effecting the others. I think I would
> make the trimmers multi-turn and of a higher value than the fixed
> resistors.
> What I haven't thought out yet is how the divider would connect
> to the keys
> so that you could have a switch between lowest note or highest note
> priority. Or how to make sure that two notes pressed at the same time
> don't short out part of the divider network. I'll have to look at some
> schematics.
> Decent trimmers can be purchased in the ~$2 range. So, I don't see why it
> has to be that expensive.
> Stooge Larry (who is probably missing the obvious)
> > From: ivancu@...
> keyboard with a
> > Ivan
> http://click.egroups.com/1/4053/5/_/529958/_/959722281/
2000-05-30 by Paul Schreiber
> From: Paul Schreiber <synth1@...>about
> Date: Tuesday, May 30, 2000 5:26 PM
> Somewhere I have my design for a digital, monophonic keyboard. No CPU,
> $8 in parts +built
> the DAC. I used a 8-bit (BARF!) but today I'd use a 12-bit.
> If I can find the plans, I'll give away free copies. It does work, I
> 3-4 of these.
> Has low-note priority, Gate and Trig outs.
> Paul S.
> http://click.egroups.com/1/4056/5/_/529958/_/959725334/
2000-05-30 by davevosh@aol.com
2000-05-30 by Nathan Alan Hunsicker
"J. Larry Hendry" wrote:
Sounds like a DAC is the way to go.
LH----------
about
> $8 in parts +
built
> 3-4 of these.
> Paul S.
2000-06-02 by Dave Bradley
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Tuesday, May 30, 2000 5:27 PM
> CPU, about
> $8 in parts +
> If I can find the plans, I'll give away free copies. It does work, I built
> 3-4 of these.
> Paul S.
