Re: [motm] My new cabinet - one man's tale
2000-04-29 by J. Larry Hendry
From: Dave Bradley <daveb@...> I stained it with 2 coats of MinWax red oak, first treating it with a MinWax pre stain to even out the color since birch is kind of soft. Then I applied 3 coats of polyurethane, applying steel wool before the last 2 coats. The finish rocks! The secret for me turned out to be MinWax Wipe On Poly. Dave, Thanks for sharing your experience and photos. I would like to echo Dave's comment on Wipe-on poly. I first found this about 15 years ago. Since then I have never used anything else. You have to be a total smuck not to be able to get a nice even finish with this stuff. It goes on so thin, you need more coats. BUT, no long dry time, no bubbles, no runs. It is the best. I am pleased to hear that you are still embracing the idea of the magic bus. I still have not had a chance to look into getting the paint finish on mine. I would be interested in hearing how you plan to implement the new rails and the magic bus. I am "thinking" about flat rails where the modules do not contact the magic bus and "L" shaped rails (recycled from my rack stuff) for the modules next to the magic bus. I am also thinking about the center wood support properly cut out to accept the magic bus. So many options, so little time. Stooge Larry
