Index last updated: 2026-04-03 18:09 UTC
Delay Module
Delay Module
2000-04-20 by Tkacs, Ken
How feasible is this idea of creating an 'analog delay' using digital RAM?
Is that an oxymoron, or is this a legitimate concept?
The good points of course are that you don't need bucket-brigade device
chips that will go out of production, and extensibility. It sure would be
cool if such a module could be based on, say, PC EDO RAM DIMMs or something,
with lots of extra sockets so that DIMMs could be added later.
Think about it-a few years from now when your Pentium III is a boat anchor,
you can throw the PC out and move the RAM into the delay module to get some
real use out of it!
Delay Module
2002-02-26 by mmarsh100
Hey All -
I know this has been discussed a little in the past, but I'd like to
bring it up again.
I think it would be very useful to have a simple delay module for my
MOTM (a resounding *Duh* from the audience).  I know I'm coming late
to this particular party, but it seems like a good thing for making
comb filters, phasor and flangy thingys, delaying envelopes, etc.
I'm talkin' really simple here: delay variable from 0 to maybe 5 ms,
knob for attenuating the mod input, jack for mod input, jack for
signal input and jack for output.  No feedback needed, no internal
modualtion.
Wouldn't this be simple to build and highly useful?
Mike
Re: [motm] Delay Module
2002-02-26 by John Blacet
"No feedback needed,...."
I think you would really need feedback!
___________________
John Blacet
Blacet Research
http://www.blacet.com
RE: [motm] Delay Module
2002-02-26 by Brousseau, Paul E (Paul)
I think it would be amazingly useful, but Paul has stated, on several
occasions, that he does not intend to make such a beast, partially for
the fact that there are others on the market which are plenty good, and
partially due to parts scarcity.
Too bad.  But I'm still hoping he'll reconsider one day...
--PBr
Sent: Monday, February 25, 2002 4:33 PM
To: motm@yahoogroups.com
Subject: [motm] Delay Module
Hey All -
bring it up again.
modualtion.
Re: Delay Module
Feedback on the suggestion, yes!  On the delay, maybe not.  That's
what the Time Machine is for!  A 'little' delay would free up a TM to
do 'bigger' stuff.
Remember, I suggested very small delay times: 0 to 5 ms, or even 2.5
ms.  Do you still need oodles of bucket-brigade for such short
delays?  If not, then the chip problem is moot, no?
Mike
> ___________________
> John Blacet
> Blacet Research
2002-02-26 by Paul Schreiber
a) There is not much I can do about the lack of BBD chips
b) That leaves DSP/digital solutions. Which is "allowed" but then get a Boss pedal for $45, rip
guts out, put on blank panel. If I did one, I'd be a $189 kit and everyone would squeal like a
pig.
To: <motm@yahoogroups.com>
Sent: Monday, February 25, 2002 6:59 PM
Subject: RE: [motm] Delay Module
> --PBr
> -----Original Message-----
> From: mmarsh100 [mailto:mmarsh@...]
> Hey All -
> bring it up again.
> modualtion.
Re: Delay Module
Again, coming from a total electronics dumb-bell, with such small
delay times couldn't you do this with discrete parts?
Mike
> pig.
> Paul S.
2002-02-26 by The Old Crow
Paul,
  Just offer a Quantec clone, kit version only.  Use something like 200
stages and just by parts bulk pre-packed in bags of 200 so you don't have
to kit them at all.  Then laugh evilly as you think of the people building
the Quantec clone. ;)
Crow
Re: Delay Module
I take it from this message that even a small delay in the ms range
is not feasable?
--- In motm@y..., The Old Crow <oldcrow@o...> wrote:
>   Paul,
200
don't have
building
> Crow
Re: Delay Module
2002-02-26 by coyoteous
I read somewhere that CCD chips might be a viable alternative.
> pig.
> Paul S.
But what about voltage control? I use an old Digitech
TimeMachine 7.8 DDL that has a control voltage input - it's kinda
crappy sounding, though.
I used to use a Lexicon PCM-42 which also has a CV in - but,
sold it when the prices got ridiculously high. I think the PCM-41
has a CV in and those can be had for $300 - $400
On a similar note, I just resurrected my old Moog 12 stage phase
shifter (CV in & LFO out). Voltage controlled FX are just more fun
in a patchable context.
Barry
Re: Delay Module
This is kinda too bad because the effect is very nice. I'll post a
file to the files section that demonstrates one of the effects.
> is not feasable?
> >   Paul,
like
> 200
> don't have
> building
> > Crow
RE: [motm] Re: Delay Module
What's a CCD chip?  I thought those were the light-sensitive things they
used in digital cameras...
--PBr
Sent: Monday, February 25, 2002 5:44 PM
Subject: [motm] Re: Delay Module
Re: [motm] Re: Delay Module
Not really. You need to have several steps:
1) Conversion and storage means on the incoming audio. A BBD chip is a black of many small
capacitors (like 512 of them). There are 512 analog switches inbetween them. The audio (AC
voltage) is "dumped" on a capacitor.
In digital delays, the audio runs through an ADC (analog-to-digital converter) and the sample is
stored in RAM.
2) Output conversion means from storage to audio. In a BBD, this is "free" because you are
retrieving the original charge (OK with added noise and 'droop'). In a digital delay, that is
done with a DAC (digital-to-analog converter).
3) Clocking means. This "shifts" the sample along in the storage means to get a delay. If you
have 512 BBD stages, and you want 5.12ms of delay, that's...errrr...(looking for slide
rule/MathCAD/abacus) a clock period of 10us or 100Khz. Most BBDs won't operate this fast, which
is why you see "minimum delay" in the 10ms range. In the digital world, we can go
full-tilt-boogie and "cheat" by picking off from ANY RAM location. A BBD has fixed "taps" and so
we are forced to chug through the whole thing.
Re: Delay Module
things they
> --PBr
Yes, Charge Coupled Device(?) used in cameras - again, I just
recall someone theorizing it's possible use as an analog delay -
maybe on SynthDIY or AH.
Barry
Re: Delay Module
things they
> --PBr
Barry
Re: Delay Module
OK, I got it.  Capacitors 'store' charge.  Too bad, the effect is
nice.
So if I was to buy a Boss delay and MOTMize it, would it be hard to
match
the power to MOTM?
Mike
> stored in RAM.
(looking for slide
world, we can go
> Paul S.
Re: Delay Module
2002-02-26 by mate_stubb
Nobody is mentioning the most interesting use for a voltage
controllable delay with very short delay times - analog physical
modelling. To do 'tuned resonator' types of blown pipe emulations one
needs precise voltage control with sub millisecond resolution, along
with voltage control of feedback. If it has to be digital to achieve
that much control, so be it - but it will take a purpose-built
design, not a hacked up pedal.
Check out this article about Ron Berry and his analog acoustic
modelling techniques, if you are not already familiar with him:
http://www.sospubs.co.uk/sos/1997_articles/jul97/ronberry.html
I've often wished to talk with him in greater depth - I'd dearly love
to explore this side of synthesis. I wonder what technology he used
to build his own delays...
Moe
do 'bigger' stuff.
Re: Delay Module
Yes!  Very cool, indeed.
Mike
one
along
achieve
love
> Moe
to
> do 'bigger' stuff.
2.5
Re: Delay Module
2002-02-26 by paulhaneberg
I've been playing around with ideas for delay modules for some time.
I would use a ADC of presumably 16 bits or better on the input with
a fixed filter at around 20 kHz.  The converted data would go into
RAM of a fixed length then come back out through a DAC and another
filter.  Most delay lines vary the point at which the data comes out
of RAM.  This is why you get zipper noise when varying the delay
time on most digital delays.  In order to do away with the zipper
noise you have to vary the clock speed.  You would want to do this
with voltage control.  I'm not sure if you'd want the frequency
response of the clock to respond linearly or exponentially or
logarithmically to the control voltage.  A selection of all three
would be interesting.  The problem is (and I don't know the answer
yet) Over what range can you vary the clock rate of the converters
and RAM?  This is something I'll be playing with in the future if I
ever get caught up on module building and get started on some of my
own ideas.  It doesn't sound cheap though.
I agree that you can do a lot of interesting things with short delay
times.  Although most delays do not go below 1mS you can do some
great stuff in the 50uS to 1mS range.  One of my favorites is to
split a mono signal and delay 1 side my a sub ms amount.  Great for
really strong stereo imaging.
I think you would want the feedback as well.  Ideally, I'd make the
feedback amount Voltage Controlled with a VCA.
Interesting Stuff.
2002-02-26 by jhaible
I thoght about building something like that in the past, but there was
always one think that kept me from really doing it:
The BBD line can be "played in tune" if you have an exponential
clock VCO. But for physical modelling, you need a filter in the
feedback path, don't you ? And every filter has some extra phase shift
(i.e. frequency dependend delay), so it will make the model go out of tune.
In a fully digital implementation you can correct this, but in analogue ?
JH.
Re: Delay Module
2002-02-27 by coyoteous
The audiophile* version: make it 24 bit and give it a fairly high
base sampling rate (96 kHz?), so you could sweep down to half
the base SR and up to double (with 192 kHz capable parts) and
still use a fixed full audio bandwidth anti-alias filter? Linear
voltage control and/or exponential for the for the physmo stuff?
Manual selection of taps would be excellent. You could have
multiple taps by digital mixing and/or multiple DACs. The same
basic module could be optimized for longer or shorter delay
times. Problems: expense,  jitter, RFI - but, could it work?
*From my understanding and experience, this is what it would
take to get close to high end analog (MOTM quality?) with digital.
Barry
some time.
with
into
another
out
delay
this
answer
converters
some of my
delay
some
Great for
> Interesting Stuff.
Re: Delay Module
2002-02-27 by paulhaneberg
24 bit would certainly have improved sonic quality over 16 bit, but I
think you could probably get a bigger variation in clock speeds with a
16 bit.  If the converter is less complex the actual conversion would
be quicker assuming a succesive-approximation type converter.  I don't
know what the highest number of bits available in a flash converter
is, but presumably this could be clocked at higher speeds (up into the
MHz range)  There are 24 bit converters available that can convert at
192 kHz, but cost is an issue.  Another possibility is to use a
one-bit converter at even higher clock speeds.
I would definitely use a filter at a low fixed frequency like 20kHz.
One of the pitfalls of this module ideas is that in order to be truly
musically useful the voltage to frequency conversion for the clock
must be very accurate over a wide range.  I'm not sure how possible
that is in the MHz region.
Multiple taps are easily implemented.  A range of delay times from
very short to reasonably long could be available.  This is simply a
function of the amount of RAM.
Even 12 bits would probably be an improvement over an analog delay.
I think a module of this sort would be very useful and popular as long
as the cost was not too high.
At some point I will probably try to build this thing and find out.
2002-02-27 by Tony Karavidas
24 bit 192kHz is a real misnomer. I can't think of any affordable 24bit A/D
that goes anywhere near that speed. "Real" converters that can put out a
real 24bits are only good for a few kHz (the last time I looked)
Audio "type" converters have a 24bit output word, but typically about 5 of
those bits are marketing bits. Look at the SNR and DR of the ADC for the
real story.
I don't think you'll have any luck VCing (by varying the clock) a
delta-sigma converter anyway. They almost all have internal PLLs that
wouldn't like a radically changing clock and many of them have async timing
inside that is very dependant on specific external frequencies. They figure
out what the external freq is and make timing adjustments.
If you want to use variable clocks, you're better off doing it the old
fashioned way (think Deltalab gear)
Tony
> From: paulhaneberg [mailto:phaneber@...]
> Sent: Tuesday, February 26, 2002 6:42 PM
Re: Delay Module [OT]
That's why I said "expensive."<g> But, 18/20/24 bit converters - even
a crappy midiman Flying Cow, are for the most part superior to a
crappy 16 bit converter. At my day job, I regularly brutalize 16 bit
recordings to make them into "realy loud" 14-15 bit recordings. About
10% of the masters I handle are mixed to a resolution greater than 16
bit - I can almost always make these sound better than their 16 bit
counterparts. The reason - "the most misunderstood of all bits" - #17.
This guy lets us turn a 17-18 bit recording into a "really loud" 16
bit recording. Also, even on on a cheap "24 bit" converter, there is
some "good" signal at and under the noise floor, just as there is with
analog tape.
That said, you're right - it's probably not worth the expense/effort.
Lest I take us even further off topic (MOTM - right?), my real
interest in all of this is in efficient, cheap and high definition
exchange of information between the analog and digital worlds,
particularly control signals. At this point, we're kind of stuck with
midi or convoluted "ghost electronics." I'd like to have digital
processing/generation under analog control and analog processing/
generation under digital control. How's about a MOTM or Encore "ghost
electronics" translation module? It's kind of a natural extension of
(or off shoot from) the midi<->cv thing and I bet it would sell at
least as good as a triple reversible attenuator (or maybe not). <g>
Barry
> real story.
> Tony
> > From: paulhaneberg [mailto:phaneber@o...]
> > To: motm@y...
2002-02-27 by media.nai@rcn.com
That sounds like overkill to me.  Based on research papers that I've read,
and my own ears, 24/96 conversion doesn't sound any better than 24/44.1
conversion.  Higher sampling rates only seem to matter when mixing or
altering sounds within the digital realm itself.  Regardless, I'd take the
Pepsi challenge with my 18/48 PCM-80 against any of these consumer 24/96
delays any day of the week.
>real story.
This is true.  There are many 16-bit converters that sound better than
24-bit converters.  While there is a noticeable difference between 16-bit
and 20-bit, the difference between 20-bit and 24-bit seems insignificant.
>In order to do away with the zipper noise you have to vary the clock
>speed.  >You would want to do this with voltage control.
I believe this is how the Korg SDD-2000 works, but it doesn't have voltage
control.
I have five digital delays, and four of them have voltage control.  It's a
very common feature.
However, none of them can pass DC, which is what I would want in an motm
digital delay module.
>>Boss pedal for $45, rip guts out, put on blank panel. If I did one, I'd
>be >a $189 kit and everyone would squeal like a pig.
Could I get a sample of that sound?? :)
Re: Delay Module
that I've read,
than 24/44.1
I tend to agree, but that wasn't my point. The idea was to get
20khz bandwidth and the bottom end of the control range - 192 at
the top, 96 in the middle, 48 at the bottom.
better than
between 16-bit
insignificant.
Converters tend to come in increments of 8 bits these days.
It's a
Can you name one that is still in production?
want in an motm
Now you're talkin', I suppose if it were for cv range only it could be
pretty cheap to make. Otherwise, that's where the "ghost
electronics" come in.
Barry
