RE: [motm] Cabinet Question -- Assembly
2000-04-18 by alt-mode
Ken, See the attached jpeg. It appears that the brace is glued into a routed slot that is set back from the front of the cabinet.  I presume that the brace is
Re: [motm] Cabinet Question -- Assembly
2000-04-18 by J. Larry Hendry
Properly clamped, glue is often stronger than the wood itself.
Larry H
Wow, I wouldn't have thought glue would be
enough, but I guess it is! Hmm...
