RE: [motm] Cabinet Question -- Assembly
2000-04-17 by Tkacs, Ken
Thanks! When you say 'glued into slots,' are these slots that are built up from wood shims, or are they chiseled into the side panels...? Maybe they are cut into the side panel with a router, and then the beams are glued and hammered until they 'pop' into place...? Am I over-thinking this? If you could take a close look tonight, I'd appreciate it. I was looking on the web for photos, but the photos people take show more of wiring harnesses, modules, etc. and not so much the wood cabinet joinery and the wooden exteriors.
-----Original Message----- From: alt-mode [mailto:alt_mode@...] Sent: Monday, 17 April, 2000 4:43 PM To: motm@egroups.com Subject: Re: [motm] Cabinet Question -- Assembly The main horizontal beam on a Moog lower cabinet is glued into slots on each side. I'll have to check if it is visible. There is one brace in the middle of the beam connecting to the bottom of the cabinet. This evening I can send out one of the pics I took showing the flat rails that also shows the joint at the side of the cabinet.
