Re: [motm] Machine Screw This
2000-04-13 by J. Larry Hendry
Actually, I am planning to continue to use the longer ones.  I know I may
have to hollow out behind the flat rails just a bit (maybe 1/16") depending
on the thickness of the flay rails.  I have these nice black nylon washers
I am using under the screws.  So, I don't think 1/4" would be long enough.
I wonder how they measure them.  Threads only?  Or, overall including the
head?  I measure Paul's at 3/8" of threads only.
Paul are yours considered 3/8" or 1/2" ??
LH
> From: Tkacs, Ken <ken.tkacs@...>
> To: 'motm@egroups.com'
> Subject: RE: [motm] Machine Screw This
> Date: Thursday, April 13, 2000 4:24 PM
> These wouldn't be the ones Paul is currently using for the rack rails,
but
> rather, something more like what I expect to be used for the cabinet
rails.
>  -----Original Message-----
> From: 	J. Larry Hendry [mailto:jlarryh@...]
> Sent:	Thursday, 13 April, 2000 4:07 PM
> To:	motm@egroups.com
> Subject:	Re: [motm] Machine Screw This
> > These guys have a nice search engine where
> > you specify the threads, diameter, head type,
> > length, finish, etc. ... and it comes up with a quote.
> > They have black #8 32x1/4" pan heads, $10 for 1000, supposedly.
> > http://www.aaronsmachinescrews.com/
> That would surprise me.  I have not found the 8/32s that Paul uses in
> phillips head.  However, they are common in hex or cap heads.  Many
stores
> have those in 4/40, 6/32, 8/32, and 10/32.  I have usually found them to
be
> around 49 cents each in singles.
> Motown & Soul Fanatics: Baby we need your ratings!
> New Music Site seeks song raters with a fine ear.
> Share what you know, and get compensated too.  JABOOM
> http://click.egroups.com/1/3346/3/_/529958/_/955661543/
Ken, I did visit this link you sent.  Cool link for hardware.   I searched
for 3/8" screws.  They were quoted even cheaper.  I just can't seem to
believe those prices.  $7.37 for 1000.  That's less than 1 cent each.
Surely that can't be right.  Are you going to order some to see what they
are?
Larry H
stores
be
