german kickback?
2000-04-12 by Nathan Alan Hunsicker
Has anyone been having problems with a german server
(ruhr-uni-bochum.de) sending a spam warning whenever you post to
egroups? Is this a list members server? if so he/she may want to let
their ISP know because I think all the egroups email is being blocked.
-Nate
Here is a copy of what I received after posting:
Subject:
delivery delay notification / Zustellverzoegerung
Date:
12 Apr 2000 23:20:54 -0000
Postmaster+relsreply-1=ad6309087b1c6dde64c099de57f52165=nate=etanstudios.com@...
To:
<nate@...>
For details see below.
If you can't do anything about the problem detailed,
or if you don't care, or if you just don't understand,
just reply to this message from the same address
you sent the original message from.
There will be no more delays after that.
Zu Detail siehe unten.
Wenn Sie nichts an dem untenstehenden Problem aendern koennen,
oder wenn es Ihnen egal ist, oder aber Sie verstehen diese
Mail nicht, beantworten sie diese Message bitte einfach mit "Reply"
von der Adresse aus, die auch die Original-Nachricht abgeschickt hat.
Danach treten keine Verzoegerungen mehr auf.
The mail you sent to us reached us via a host
with the IP address 151.197.134.6.
This host is known to the relay list at relays.mail-abuse.org
to be an abused open spam relay or other source of spam.
This means that other people have received spam (unsolicited commercial
email) through this host because of a (most times unintentional)
misconfiguration of its mail software.
Our host marks your (and all such) mails as "dubious" because of this
fact.
Depending on the handling by the recipient, this may result in delays
in delivery of your message, or the recipient may even decide to drop
the message without inspection.
The problem can be with your own mail system, or with the mail system
of your ISP, or even with a mailing list host or a forwarder of the
recipient.
If the problem is near your side, we recommend that you check with your
postmaster or with the ISP you sent this message through,
and find out why they operate an open relay. Possibly they can close
this relay or, if everything else fails, you might find a different ISP.
For more information, you might look at
<http://mail-abuse.org/rss/enduser.html>
or
<http://mail-abuse.org/rbl/enduser.html>.
As you probably cannot immediately solve this problem, you will not
receive this message more often than twice every 10 days.
Eine Mail, die Sie an uns gesendet haben, erreichte uns ueber einen
Rechner mit der IP-Adresse 151.197.134.6.
Dieser Rechner ist der Relay-Liste relays.mail-abuse.org
als missbrauchtes offenes Spam-Relay oder sonstige Spam-Quelle bekannt.
Das heisst, dass anderen Empfaengern Spam (unerwuenschte Werbemail)
ueber
diesen Host zugestellt worden ist, und zwar wegen einer (meist
unbeabsichtigten) Fehlkonfiguration der Mail-Software.
Ihre (und alle solche) Mails werden von unserem Mailhost daher als
"zweifelhaft" markiert.
Je nach Behandlung durch den Empfaenger kann dies kann zu Verzoegerungen
bei der Zustellung Ihre Mail fuehren, der Empfaenger koennte die Mail
sogar wegwerfen, ohne sie anzusehen.
Das Problem kann an Ihrem eigenen Mail-System oder dem Mailsystem Ihres
Providers liegen, es kann aber auch bei einem Mailinglisten-System oder
der Weiterleitung des Empfaengers auftreten.
Wenn das Problem an Ihrer Seite liegt, empfehlen wir Ihnen, mit Ihrem
Postmaster oder Provider Kontakt aufzunehmen und zu pruefen, warum er
ein offenes Relay betreibt. Vielleicht kann er es einfach schliessen,
oder schlimmstenfalls koennten Sie sich einen anderen Provider suchen.
Weitere Informationen finden Sie unter
oder
Sie koennen natuerlich auch per Reply mit unserem Postmaster Kontakt
aufnehmen.
Da Sie dieses Problem vermutlich nicht unmittelbar selbst loesen
koennen,
erhalten Sie diese Mitteilung nicht oefter als zweimal alle 10 Tage.
--- Below this line is a copy of the header of your message.
Received: (qmail 26079 invoked from network); 12 Apr 2000 23:20:50 -0000
Received: from fh.egroups.com (208.50.144.71)
by mailhost.rz.ruhr-uni-bochum.de with SMTP; 12 Apr 2000 23:20:50
-0000
X-eGroups-Return:
sentto-88644-5005-Zsolt.Homlokos=rz.ruhr-uni-bochum.de@...
Received: from [10.1.10.35] by fh.egroups.com with NNFMP; 12 Apr 2000
23:20:46 -0000
Received: (qmail 18382 invoked from network); 12 Apr 2000 23:20:45 -0000
Received: from unknown (10.1.10.26) by m1.onelist.org with QMQP; 12 Apr
2000 23:20:45 -0000
Received: from unknown (HELO qg.egroups.com) (10.1.2.27) by mta1 with
SMTP; 12 Apr 2000 23:20:45 -0000
Received: (qmail 27276 invoked from network); 12 Apr 2000 23:20:44 -0000
Received: from mail.lvwi.net (151.197.134.6) by qg.egroups.com with
SMTP; 12 Apr 2000 23:20:44 -0000
Received: from etanstudios.com ([151.197.134.149]) by mail.lvwi.net
(8.9.3/8.9.3) with ESMTP id SAA15237 for
<motm@egroups.com>; Wed, 12 Apr 2000 18:41:04 -0400
Message-ID: <38F50531.7194D8D@...>
X-Mailer: Mozilla 4.72 [en] (WinNT; U)
X-Accept-Language: en
To: motm@egroups.com
References: <ae.3a61dbf.26265d80@...>
MIME-Version: 1.0
Mailing-List: list motm@egroups.com; contact motm-owner@egroups.com
Delivered-To: mailing list motm@egroups.com
Precedence: bulk
List-Unsubscribe: <mailto:motm-unsubscribe@egroups.com>
Date: Wed, 12 Apr 2000 19:22:25 -0400
X-eGroups-From: Nathan Alan Hunsicker <nate@...>
Reply-To: motm@egroups.com
Subject: Re: [motm] Sequential Circuits Polysequencer
Content-Type: multipart/alternative;
boundary="------------069F77722E8A466A768E7978"
