RE: [motm] Vinyl lettering
2000-04-12 by Tkacs, Ken
This is exactly what I've been trying to describe. We used to call them by the trade name "Adgrafix" (decals to affix for advertising, get it?) but an Internet search reveals that this name has been adopted by about 3700 web design outfits, making it impossible to find anything.
-----Original Message----- From: David Bivins [mailto:dbivins@...] Sent: Wednesday, 12 April, 2000 2:43 PM To: motm@egroups.com Subject: [motm] Vinyl lettering I have been discussing screen-printing with another member of this list, as I have a very good connection. We will share our findings soon, I hope. Anyway, my connection also has a vinyl sign cutter which is what you've been describing for applying logos, etc. I don't think it's designed for very small work, but I could be wrong. As described by others, it is essentially a plotter with a blade rather than a pen. It uses rolls of vinyl that either have adhesive on the front (if you're doing a shop window, e.g. and want the vinyl inside) or back. You peel away that which you don't want (the in-between bits) and then apply the vinyl, already spaced perfectly as it still has the backing (which is not cut).
