Re: [motm] Re: Rear-facing cord?
2000-04-12 by Stephen Punt
Was there not some discussion on the list of a future
attenuator module with another connector board
included?
Or was that wishful thinking on my part?
I'd certainly like to see a large power distribution
solution that looked as good as the rest of the
modules.
How about a rear or front mounted 19" wide by ?U power
supply and star wired multiple connector board
arrangement as an alternative configuration?
--- jmw <evening@...> wrote:
> Considering the "you can't buy just one " factor of
> MOTM gear, you should
> try to squeeze as many connectors as possible - or
> redesign it  so you could
> easily mount another 12 or 16 connector board when
> you reach the limit
> (like I just have,  13 modules & counting!)
> John M. Wieczorek
> 14 Layne Rd.
> Somerset, NJ 08873
> (732) 249-4187
> > I am thinking about enclosing the power supply,
> and moving the AC inlet to
> > the rear. The
> > connector board may also 'grow' from 12 to 16
> connectors. Thoughts?
end
Stephen K J Punt
Do You Yahoo!?
Send online invitations with Yahoo! Invites.
http://invites.yahoo.com
