Re: [motm] Rear-facing cord? Flat rails
2000-04-12 by jwbarlow@aol.com
In a message dated 4/11/2000 10:01:29 PM, synth1@... writes: >Changing the subject... :) > >Are we all in agreement that 12U width is the preferred flat rail length? >Any arguments >for others? Given that "full length" isn't an option, yes! Being that 24U is easily obtained -- this only leaves out Bradley with his 26U. >I plan to get a quote started tomorrow. Rockin good news! In a message dated 4/11/2000 10:06:15 PM, synth1@... writes: >I am thinking about enclosing the power supply, and moving the AC inlet >to >the rear. The >connector board may also 'grow' from 12 to 16 connectors. Thoughts? Now you do it!!!! <joking> In retrospect, I would've preferred it! Especially since I'm out of power connections (as well as rack spaces). I assume same PSU? JB
