Re: [motm] Flat rails / MOTM as billboard
2000-04-12 by J. Larry Hendry
> From: Paul Schreiber <synth1@...>
> Changing the subject... :)
> Are we all in agreement that 12U width is the
> preferred flat rail length?
All in agreement ?  ROTFLMAO......  Thanks Paul.
Yes, they work for me.
> Also, was pitched the idea that the blank panels,
> on 1 side, could be screened with the logo in
> large format. If you wanted to show that side,
> fine. Else turn it over.
Except the backside is not splattered.  No thanks
to the logo on all blanks is my vote.
Larry H
RE: [motm] Flat rails / MOTM as billboard
2000-04-12 by Tkacs, Ken
12u flat cabinet rails gets my vote.
One thing you might be able to do, Paul, if you wanted one otherwise 'blank'
panel in a system to bear the logo is to offer a separate decal that could
be applied. This could be something like a bumper sticker, but I know when I
used to do capital projects for May Company we used a machine that created
these things called "Adgrafixes."
The Adgrafix machine was made by Gerber scientific, run from a PC (a 286 at
the time...!). It is sort of like a dot-matrix printer but with an Exacto
blade for a print head. You feed in rolls of colored "stuff" that was like a
very tough vinyl with very strong adhesives and a waxed backing.
You feed it a design, and the blade cuts it into the colored vinyl just deep
enough to not score the waxed backing. Then you can peel off the part you
want, apply it to glass, plastic, metal, anything, and it's semi-permanent
(you can get it off with a lot of solvent and elbow grease).
We bought our own machine, but I was led to believe that sign shops could
bang these things out for you while-U-wait for not much money.
Might be a nice alternative. This way people can place the logo wherever
they want, and the price of the blanks doesn't go up a buck across the
board.
Sent:	Wednesday, 12 April, 2000 1:04 AM
To:	motm@egroups.com
Subject:	[motm] Flat rails / MOTM as billboard
Are we all in agreement that 12U width is the preferred flat rail length?
Any arguments
for others?
I plan to get a quote started tomorrow.
Also, was pitched the idea that the blank panels, on 1 side, could be
large format. If you wanted to show that side, fine. Else turn it over.
This would add about $1ea, cost wise. I guess on 1U it would be sideways.
Any other suggestions?
as you can tell, I'm cranky
Easter Made Simple
Click Here ->
http://click.egroups.com/1/3122/3/_/529958/_/955515642/
