Future module vote - VC Phase Shifter
1999-05-12 by fuzz
Archive for motm.
1999-05-12 by fuzz
1999-05-12 by Doug Pearson
>I'll second that!
>I must chime in here and vote for a VC Phase Shifter.
1999-05-12 by Paul Schreiber
1999-05-12 by Dave Bradley
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Tuesday, May 11, 1999 8:27 PM
> To: motm@onelist.com
> Subject: Re: [motm] Future module vote - VC Phase Shifter
> Just for the *sake* of argument:
> MOTM-500 14-stage VC Phase Shifter
> Based on ARP Quadra design. VC of rate and depth, 2U wide. $189 kit.
> Any interest???
> Paul S.
> (yes it's a little $$$ but has a s**tload of parts, MORE than the VCO! But
> *cheaper* parts!)
> How many communities do you think join ONElist each day?
> http://www.onelist.com
> More than 1,000!
1999-05-12 by fuzz
>From: motm@onelist.com on Tue, May 11, 1999 9:23 PM
>Any interest???
>Paul S.
>*cheaper* parts!)
1999-05-12 by J. Larry Hendry
> Any interest???
1999-05-12 by JWBarlow@xxx.xxx
>Just for the *sake* of argument:This sounds great! I always like VCQ (or VC resonance) whenever possible.
>Any interest???
>There are several BIG differences that don't lend easily to "flip theBummer! That's what I thought you'd say.
>switch". Actually,
>guitars, mics, and syths ALL are so different that very liitle is common.
>I still want to do a good mic pre: I bought all these high $$$ Burr-BrownI agree that a good mic amp is a separate idea.
>instrumentation amps
>and AD820 super whiz-bang FET op amps for the servos.
>The guitar pre has a VERY high input impedance (like 1M) and uses a VERYI like the "sound" of this one. I guess it's too late (too expensive, and
>Linear Tech
>current-mode op amp (like $12ea!) with a LT1010 current booster for pure
>Class A excitement.
>I like the "sound" of this one. I guess it's too late (too expensive, andBecause most synths output 1V pk-pk at full volume and we want 10V pk-pk
>undesired by the rest of the MOTM crew) to have two guitar preamps in the
>module -- I'm still not sure why I'd need a "Synth Input."
1999-05-13 by Rob Johnson
>From: "Paul Schreiber" <synth1@...>Rob Johnson
>Any interest???
>Paul S.
>*cheaper* parts!)
>More than 1,000!
1999-05-13 by JWBarlow@xxx.xxx
>I am interested. I like the idea of a good flanger or phaser for MOTM.I was thinking it would be useful to switch between different inputs and
> I
>think some effetcs could be cool. But, stay away from the ones that are
>easily done externally and/or digitally like reverb / delays.
>And, NO spring reverb. These things have terrible frequency response andHere's a patch (which every 2600 user figures out rather quickly) which, if
>I
>don't think one could be made to sound good (up to MOTM specs). If you
>want a spring reverb, go build the PAiA. I did, and it sounds, well, like
>a spring reverb. This is one area where multi-effect or dedicated reverb
>effect boxes HAVE made an improvement in my opinion.
1999-05-13 by David Bivins
> Sent: Tuesday, May 11, 1999 9:27 PM
> Any interest???
> Paul S.
> *cheaper* parts!)
> More than 1,000!
1999-05-13 by Tentochi
> From: "David Bivins" <david@...>Did you build these? SNARE? BASS? How were they?
> I'm looking forward to patching up my own percussive voices; for diy perc.
> voice modules (for my education), I'll stick with the Midwest Analog
> Products modules.
> that would be done in a big-ass software environment, as it's based onDo you want to reverse the whole sample or little snippets? Do you want the
> reversing samples in realtime... Does anyone know of an audio manipulation
> environment (as Max is for MIDI) on a PC, so I could see if this
> would even sound interesting?
> Did you build these? SNARE? BASS? How were they?<hangs head in shame>Er, not yet. I'm going to soon, though! I'll let you
> > that would be done in a big-ass software environment, as it's based onIt's hard to explain--I visualize it a little better. It's basically about
> manipulation
> you want the
> MOTM to do this????
> From: David Bivins [mailto:david@...]
> Sent: Thursday, May 13, 1999 1:21 PM
> know--first is the ADV-Bass.
> From: "David Bivins" <david@...>I haven't got Thomas Henry to reply to my emails. How was your response
> > Do you want to reverse the whole sample or little snippets? Doof
> > you want the
> > MOTM to do this????
> reversing the actual samples (that make up a whole "sample") in a linear
> fashion so that the sample overall folds over itself. The user
> could dictate
> the curve by which it reverses, etc. This wouldn't really be a MOTM kind
> thing (although I guess it could be) but more of a VST Plugin kind ofthing
> or standalone digital module.ABCDEFGHIJ
> This may be a better explanation. Let's say the samples comprising a tone
> are represented by the letters of the alphabet so that the tone is:
> Now we put it through the wringer thus: ABCDEFEDCDEFGHIJWhat your are describing is extreme time-stretching. The classic use of the
> Now we control the "curve" of the reversal:
> AAAABBBBCCCCDDDDEEEEFFFFEEEDDCDDEEEFFFFGGGGHHHHIIIIJJJJ
1999-05-14 by Gur Milstein
>From: "Paul Schreiber" <synth1@...>Hi list.
>Any interest???
