Re: [motm] 320 built!!
2000-04-12 by jwbarlow@aol.com
In a message dated 4/11/2000 8:50:57 PM, revtor@... writes:
>In the parts manual for the 320 it lists the 2k resistors
>as red red red..   shouldn't this be red black orange?  Im not sure...
> In
>the docs for the 410 it lists red red red as 2k2..
Yeah Steve,
I REALLY like that Paul is listing the color code for the resistors (although
I just use a DMM for the 1% -- too much hassle). You're right about the typo
in the 320, I think Paul may have posted this to the list when the module
came out.
You are also right about 2.2K being red-red-red. So red = 2 and black = 0.
With 5% resistors for red-red-red you get, 2.2 with times two orders of ten
-- or 2200. With red-black-red (hard to tell orange from red sometimes) you
get 2.0 times two orders of ten -- or 2K.
Still changing my MOTM from  banana to 1/4."
JB
2000-04-12 by Cary Roberts
>Larry (so anal I even inspect every solder joint with a jeweler's lope
>before I cut the leads off.  Hey, it has kept me from forgetting to solder
>any of them) Hendry
Just wiggle the lead.  If it's stiff it's soldered.  If it moves
it's not.
-Cayr
In a message dated 4/11/2000 9:40:23 PM, jlarryh@... writes:
>I check EVERY resistor that goes in with the DMM.  Some of the colors are
>just too much alike for my old eyes.
>Which would be totally unnecessary if you had done it right the first time.
When I had like two MOTM modules (two years ago!) and like 20+ banana modules
(plus a bunch of mini phone to banana cords for my ARP) this seemed quite
reasonable!
>any of them) Hendry
John (farsighted -- who's been wearing glasses since age three, and now wears
two pair of glasses at the same time in order to hold the resistor about five
inches from  my face so I can.....easily see the color code -- try it, you'll
"see") Barlow
2000-04-12 by Hugo Haesaert
Hi All !
A well soldered lead should give a nice ping when played like a thumb
piano .  An unsoldered one does not .  Go on, try it ;-)
Cheers .
Keep 'em oscillating .
Hugo
