MOTM-800 version ?? Was: purchasing decision
2000-04-04 by J. Larry Hendry
The schematic for the old ones is dated  Jan 18,1999.  The new version is
dates Jan 22,2000 and says revision B in the title box.  There are only two
parts added. D4 and R16.  Functionally, the old version does not do full
ADSR with a gate only.  The new one does.  The old ones can be easily
modified with the two new parts added in.  Roy Tate sent out a good
description of how to make these changes.  It can be done in several ways.
However, when I did mine, I found Roy's suggestions to be as good a method
as I saw.  I think laying the resistor down on the board and securing the
loose end in the cable wire wrap is a good idea instead of letting it
float.
Larry H
> From: ivancu@...
> To: motm@egroups.com
> Subject: Re: [motm] Purchasing decisions
> Date: Tuesday, April 04, 2000 6:36 PM
> In a message dated 04/04/2000 7:32:10 PM, jlarryh@... writes:
> << I did modify all my 800s to work on gate only
> for full ADSR.  I recommend that to anyone with the "original" 800s. >>
> How can you tell if you have "original" 800's?
> Ivan
> PERFORM CPR ON YOUR APR!
> Get a NextCard Visa, in 30 seconds!  Get rates as low as
> 0.0% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
> http://click.egroups.com/1/2121/3/_/529958/_/954891447/
