MOTM-820 VC Lag - Preview
2000-04-03 by Paul Schreiber
Attached is Dave da Moe's panel mockup. Note the
clever built-in 3-out mult for driving 3 CVs from 1 input!
Features:
* independent UP and DOWN times
* Times are 1ms to 10sec
* Variable LINear to LOGarithmic responses
* seperate UP/DOWN control for equal rise/fall (mimic standard inferior
portamento)
* precision DC op amps for <0.5% accuracy
Also equally clever BYPASS function with is panel toggle or a
GROUND on bypass jack. The informed user will instantly see that
a simple "remote" switch, shorting out tip/sleeve of the plug will also
bypass. Red LED lites when bypassed.
Estimated ship date: early May.
Price (this I know!): $149 kit $199 assembled. Place orders anytime you
like!
JH is cheif designer on this unit.
