Maybe a little OT, maybe not
2000-03-31 by Nathan Hunsicker
Does anyone on this list know what sort of technology was used on the metalic keypads used on microwaves made in the early 80's? I had a Panasonic that had a touch pad on it, the buttons required no pressure to activate, just a touch. I'm trying to find out if the keypad was made of some expensive material or it there was extensive circuitry required to make these touch sensors work. the reason I ask is, I was thinking about some type of linear controller using pads similar towhat I was describing hooked to a resistor chain fed through a sample & hold and a lag processor to somewhat mimick a ribbon controller (since that idea is now officially out the window) Let me know what you think. -Nate
