Joysticks, 440, Nord Modular
2000-03-30 by improv@peak.org
First, the mail-lady just dropped of my 440! Cool! I wasn't even expecting it yet. Now that we'll all be occupied with building these things for a few days, the list will get back from the Sci-Fi soundtrack digressions. >From: mark scetta <n0nspaz@...> > >yes this is what i'm doing with the PC Jr. joystick, leaving the cord >length to use it remotely (not housed in a module), just cutting off the >end connector, removing the internal capacitors and bringing the X & Y 100k >pot outputs to 1/4" neutrik plugs. i have not yet determined if i'll want >to put trimmer pots on them. it's working so far. > >the FIRE button (oops i'm shouting 'fire' in a small room) will go to a >custom 1/4" jack in my MOTM custom preamp module, wired to +15v thru a >couple of resistors for use as a trigger button. can anyone recommend what >voltage i should use for this? i was thinking that 7v was a nice >compromise. (?) > Based on your message, I did this with mine, cut the end off the joystick and wired it to the +15V lead, and the outputs to 4 jacks (X + Y CV out, top and front button out). Works great, with a few quirks. First, the X voltage decreases as you move the stick left. That is, if I patch it to control pitch on a VCO, the lowest pitch is at the far left and the highest at far right. This seems counter-intuitive, but workable, I can always patch it through an inverter. Next, the front button acts wierd. The top button acts as expected, sending out +15V when pushed. The front button has 2 odd behaviours. It only sends a change when released, not when pushed, and pushing the top button also sends a pulse through the front button. Again, not a large problem, but curious. I'm sure my near-total lack of electronics knowledge is pretty glaring here. What's a recommeded resistor value for bringing the button voltage down to a level the 800 EG's can handle? And, I have to confess, I guess last night I went over to the dark side. I got a used MicroModular in a trade deal. Spent most of last night playing with it. Sonically, it occupies a totally different space than the MOTM: cold, precise, very focused sounds. I expected this because I have a Nord Lead, and, the 2 sound very similar, unsurprisingly. What really strikes me about the Nord Mod, though, is that this is analog modelling done right! I know we can argue the validity of analog modelling when great analog systems like MOTM are available, but at least the Nord Mod is a very flexible system, unlike the other VA synths (Roland 8000, etc). My main intention for the Micro is for gigging, it plus a PC-1600 makes for a very portable system for throwing in some noise. Until I can afford to pay roadies, I think the MOTM is staying home. ____________________________________________ Dave Trenkel : improv@... Minus Web Site: http://listen.to/minusmusic Minus MP3's: http://www.mp3.com/-minus- ____________________________________________
