Paia Theremin
2000-03-30 by Tkacs, Ken
<<Theremin-PCB in 2.jpg>> Here's a picture of my Paia-based Theremin before final assembly and wiring (for clarity). The antennae were made from copper bus bar (got a nice loop for the volume antenna by pulling it around a metal column in my basement). I made it so that the antennae could be removed with a wing nut for transport. You can see that I followed all of the suggestions, including a piece of sheet metal under the spacers holding up the PCB. The front panel has an extra rotary switch that isn't wired to anything at this point-I was going to play with the different coupling "gimmick" suggestions and put them on the rotary so that I could switch between them. I'm very bummed that this thing wont make a peep. Not even hum.
