VCO's wiggling yet?
1999-05-07 by Paul Schreiber
Archive for motm.
1999-05-07 by Dave Bradley
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Friday, May 07, 1999 3:14 PM
> To: MOTM listserv
> Subject: [motm] VCO's wiggling yet?
> Except for Dave "The Rocket" Bradley has anyone got a VCO up?
> How are the instructions?
> Like the new switches??
> TEST those power cables!!
> Paul S.
> Wanting to get back in touch with old friends?
> http://www.onelist.com
> Reunite through a ONElist community.
1999-05-08 by JWBarlow@xxx.xxx
1999-05-08 by Paul Schreiber
>I did get my VCO working yesterday but spent an inordinate amount of time1) If you are use a freq counter, then use the SYNC I/O jack with the switch
>calibrating it. I really love the instructions (especially the theory of
>operation). Yes, I had problems with the power cable and that added to the
>time it took to calibrate it; I was able to fix the pins on it properly.
>sync
>I do have a question for Paul and other VCO users: I'm experiencing a
>frequency drop when I switch from soft to hard sync (with nothing at the
>input!). At 1440 Hz in the hard sync position, it drops to about 1360 Hz inLook at the schematic. In SOFT mode, the sync pulse is feeding back into the
>soft sync. I don't hear a pitch drop at around 90 Hz (I don't trust my freq
>counter at this low freq), so it seems to scale differently in the hard and
>soft sync positions. Does anyone else notice this behavior?
1999-05-08 by Dave Bradley
>From: JWBarlow@...sync
>input!). At 1440 Hz in the hard sync position, it drops to about 1360 Hz inI do not see frequency shifts when I switch the sync switch back and forth
>From: Dave Bradley <daveb@...>in
>At 11:55 PM 5/7/99 -0400, you wrote:
>>From: JWBarlow@...
>sync
>>soft sync. I don't hear a pitch drop at around 90 Hz (I don't trust myfreq
>>counter at this low freq), so it seems to scale differently in the hardand
>in the two VCOs I've completed. I do see a drop if I switch to Lin and DC,
>but that is documented.
>Rocket Man
>ONElist: the best source for group communications.
>Join today!
>From: JWBarlow@...in
>Thanks to Paul and Dave for checking their VCOs. As usual, it was my fault
>that I'd misconnected two of the wires to the sync switch at the PCB.as
>Apparently it isn't enough to read the directions, you have to follow them
>well! Damn! It's always somethin'. Everything is working properly now withno
>significant pitch drop between the sync positions.it
>Even after taking it apart, and resoldering a few other places on the PCB,
>only needed a slight tweak to rescale it. I think the VCO has raised the
>(already high) standard for MOTM kits!
>But I still hate that heat sink compound!
>JB
>Join today!
>From: "J. Larry Hendry" <jlarryh@...>
>> One thing in the instructions that gave me pause for a second was when
>they
>> casually ask you to solder the vias. I asked myself "Is he really asking
>me
>> to put solder in ALL the via holes?" After I thought for a second, I
>figured
>> that since it was a high performance circuit, soldering all the vias was
>in
>> fact justified. That's what I did, since it can't hurt anything.
>Huh? "Splain this to be better Lucy."
>Larry H
>Always wanted to set up a book club, but can't find the time?
>Create an online book club through ONElist.
1999-05-09 by J. Larry Hendry
> I definitely like the new switches better. Finer threads on the barreland a
> backing nut to help protect against torque monsters (you know who youare!)
> One thing in the instructions that gave me pause for a second was whenthey
> casually ask you to solder the vias. I asked myself "Is he really askingme
> to put solder in ALL the via holes?" After I thought for a second, Ifigured
> that since it was a high performance circuit, soldering all the vias wasin
> fact justified. That's what I did, since it can't hurt anything.Huh? "Splain this to be better Lucy."
1999-05-09 by Paul Schreiber
>How about: "I always do this by habit but thought that others may need to be
>Why doesn't Paul have us solder these holes for all the kits? I suspect
>because this is a higher performance circuit, and a denser design, but I'm
>sure he can tell you his reasons.
1999-05-09 by fuzz
>From: motm@onelist.com on Fri, May 7, 1999 4:40 PM
>To: MOTM listserv
>Paul S.
>The instructions were wonderfull as usual. I especially liked the proximityred
>clues. One minor correction: page 2 parts list says that R52 220K is red
>orange, should be red red yellow.%$@#$^@#!!
>filling
>The soldering of the via holes made me also think about going back and
>my other MOTM boards. I guess one day I'll overhaul them, but not today asSorry, I sort of do this on autopilot. If you go back to do this, use the
>they seem to be working OK.
>on
>The heat sink compound seems to be available in 2 flavors - silicon &
>non-silicon. Don't know if it matters at all, as long as you do not get it
>your jeans ;-)The silicon is better! But "goopier" and harder to clean-up.
> From: "Paul Schreiber" <synth1@...>be
> instructed speciffically"I am one of those "may need to be instructed specifically kind of guys."
> Or the Steve Martin version: "I FORGOT. EXCUUUUUUUUSE MEEEEEEEE!"Of course he also said "I'm one wild and crazy guy." Probably because of
> Paul S.
> arrow through head
1999-05-14 by improv@xxxx.xxxxxxxxxxxxxxxxx)
