Re: [motm] Vocoder plans?
2000-03-16 by alt-mode
Sounds quite interesting Paul, I'd sign up for one but I'd want to get more detail on just how long the R&D cycle would be ;) Eric --- Paul Schreiber <synth1@...> wrote: > JH & I are just "tire-kicking" the vocoder idea. We are NOT trying to > rip-off EMS! Rather, just > in the info-gathering stages. > > The MOTM plan is NOT to be in the $600 range, but more like the $1400 range. > There is just > too much R&D and parts. it would be 90% assembled, like the MOTM-900 is. > Mostly SMT, due > to the vast number of parts (like 280 op amps!) It will need it's own > supply. > > Also, there are many, *many* tradeoffs. The much-touted Sennheiser uses 40 > bands (not very > sophisticated filterd, a 2-transistor BP) but is hand-tweaked! Also, it is > set for "best response" > for vocals, not necessarily a wide range. > > And then it has 138 panel controls...........hmm...... > > But then again, only 60 were made at $18,000ea (the current price is > $5000-$7000). > > Not really interested in a "small" PAiA/MAM 11-band for $600. Why? Ask > anybody that owns one. > They do "work", but if you are really into Kraftwerk-type quality, *AIN'T > GONNA HAPPEN* with > the low-end stuff. > > If we DO decide, then we will ask for $500 deposits to get the R&D effort > off the ground. > > <Paul S> > > > __________________________________________________ Do You Yahoo!? Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com
