Re: [motm] CV Monitor
2000-03-09 by thomas white
Howdy, I just finished building a couple of CV monitors per Ken's .jpg and they are great. You can really get a little light show going with one on each spare output of your VCO's! I recommend all you LED freaks build at least one to fiddle around with. I used a Bi-Color LED and mine actually lights Red for pos (+) and green for neg (-) with yellow in the middle of the spectrum. Fun little additions to an already exciting playground. Thanks Ken, Thomas White >It is a CV/Signal monitor. Basically you just take a tri-color LED (they >were pretty new at the time, very hot stuff) and solder it into a mono \ufffd" >plug with a 560-ohm resistor in series with the tip as shown. >(Green-Blue-Brown, 560, right? Don't have my Monday morning coffee yet). > >The LED lights green for positive CVs, red for negative, and yellow for >signal (actually the 'yellow' is just a result of the red and green diodes >flashing back and forth quickly... it starts to look yellow even at fast >LFO >rates). > >What you see in the photo is the one I built, very simple. I used Letraset >press type to label it and sprayed a little fixative on it. It's crooked >but >has survived the test of time. I used acrylic paint to label color swatches >and label those, but the white paint seems to have rubbed off over the >years. It looks worse in this magnified view than it does in real life. > >So anyway, there you have it. Build at least one. Enjoy! Now you have a >portable fancy LED that you can stick anywhere in your rig! Has Paul come >out with a new module and didn't give you that tri-color LED that you >wanted? Just plug one in! Amaze the family! > > > > ><< CVmonitor.JPG >> ______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
