Pulse Divider
2000-03-09 by Paul Schreiber
> Well, I'm sure there is at least one guy on this list who'll really like this > module. I seem to remember about a year ago some loudmouth would post lengthy > diatribes regarding VC Division, claiming to use several of these to control > sequencers (resets, up/down, random, etc.) and synching up several different > voices amongst other uses. > This is a joint Paul S./Old Crow development, using not 1 but 2 PIC microprocessors. There are mechanical issues to be resolved, but the circuit is in beta test this month. And, you can run audio into it. The outputs are "CMOS" levels, ie 0 to +5V as driven by a 74HC244 buffer. So there will be a volume drop as compared to standard -5 to +5 audio. This is the *plan*. However, I need thouse of you with Roland drum stuff (303/808/505/606/blah blah) to look in the manuals and see if Roland states what they expect CLOCK IN to be. If is a higher voltage, I'll have to buffer things differently. Features/panel shots in about 10 days. As a teaser, it contains visual indication means. Paul S.
