Archive for motm.
Labeling mods
Labeling mods
1999-01-25 by CHRIS PARKER
Greetings MOTM builders!!!
Has anyone (everyone?) else added the Vibrato Source Select Switch modification to the MOTM-100 Noise/S&H module? If so, how did you handle labeling the new switch? I'm looking for some way that will do justice to these beautiful panels!
Thanks!
Re: Labeling mods
1999-01-25 by Paul Schreiber
As a general answer:
the font is called "Alternate Gothic 2". This is the same as the Moog
modular.
Originally, a company called ChartPAK make rub-on lettering with this font.
I used to buy these, by the sheet, at local college bookstore. About 1 year
ago, I was at an "old fashioned" drafting supply store (pre-AutoCAD) and lo
and behold, there was a small rack of ChartPAK letter sheets.
Re: Labeling mods
1999-01-25 by Thomas Hudson
I've spent the last two weeks setting up a LAN in my home
w/ full time access to the Net. As soon as the seemingly
never-ending sysadmin nightmare is over, I plan on setting
up a MOTM page to collect modifications. I have two so far;
1) MOTM-100 : Vibrato Source selection switch
2) MOTM-120 : AND/XOR Switch and daughterboard
The labeling has been my main hesitation. I'll save this
tip to add to the MOTM page. BTW, is this list archived?
Thomas
P.S. You can see the not too pretty fruits of my labors
at http://www.tomy.net . Not much, but at least the web
server is up and running. Mechanics before beauty, er,
content.
Paul Schreiber wrote:
> modular.
> Paul S.
> To unsubscribe from this mailing list, or to change your subscription
> to digest, go to the ONElist web site, at http://www.onelist.com and
> select the User Center link from the menu bar on the left.
