Help with joystick
2000-02-28 by thomas white
Hi again gang. I am planning to make a joystick controller on my own as a learning experience. I will be using the CH Mach-2 joystick from CH products as previous mentioned in a message by Nathan H. Can anybody help me out with a schematic for the +5/-5v circuit I need to use with the joystick? I have a block diagram of the circuit, but nothing specific. I want this to be of good quality to work into my MOTM so anything complicated is not frightening at this point. :~) I like how this joystick can release either spring loaded axis at a time or both for free floating movement. Would I be able to use the two joystick buttons to generate 5v triggers to fire EG's or re trigger LFO's? I figure the panel would include the DB-15 connector, 2 pots, X & Y outs, and maybe 2 Trigger outs? Please advise my friends. 1 connector, 2 pots and 4 jacks = 1 space MOTM panel. Or do I even need the CV adjustment pots due to the trimmers on the joystick? Thomas White ______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
