Daughter of MOAS
Daughter of MOAS
1999-04-04 by Paul Schreiber
Well, here is a thought for an intermediate version (non-MOAS).
1) Use Spectrol 248 conductive plastic pots (the black ones on the '110
kit). I get those for
about $2.75ea.
2) Use a 12-bit ADC to read them in, and a 12-bit DAC for the output.
3) Use a 8051 uP (I have full-tilt boogy tools for 8051 and as a warning I
LOVE assembly).
4) Use a standard 2 line 16char LCD display or I have a surprise for an
equivalent. Both cost me about $20.
This would fit in a 3U wide, kit would be $400-500, and you get 1X16, 2X8
with EEPROM program storage,
sync to MIDI clock, etc etc etc. Glide, quantizer, SW upgrades off the net,
blah blah blah.
Takers????
Mr. Mico
Re: Daughter of MOAS
1999-04-05 by Paul Schreiber
I don't understand the issues here.
You want a quantizer: what is a "quantizer"? Well it takes a continuous
voltage
and assigns it to discrete steps. What better to do this than a uP? That
way, under
software, you can have YES/NO quantizing for EVERY pot. You can quantize to
both
chromatic and non-chromatic scales. You can save the setting in EEPROM. You
can have
equal time-per-step like a Moog 960 JUST AS EASY as you can have a data
entry knob
and set the time between notes (relative or in MIDI clocks).
This sequencer DOES NOT REQUIRE MIDI at all. The "default" configuration is
a super Moog 960.
The 8051 has a FREE UART that is 100% MIDI compatible and I have the code
already written!
(used in my Master's Thesis).
You want different triggers? What better way than a uP? Repeat on stage N,
random stages, cycle N times then stop,
wait for N pulses then RUN, etc etc etc. This is HARD in hardware but EASY
in software. All you do is hook the
clock to the Interrupt pin.
I'm NOT trying to make a Maq. I'm trying NOT to use 25 chips to do what a
8051 can do in 3.
To: motm@onelist.com <motm@onelist.com>
Date: Sunday, April 04, 1999 6:53 PM
Subject: [motm] Re: Daughter of MOAS
>From: Gur Milstein <gur-m@...>
>Hi.
>no no no just not a maq clone it sucks.
>i dont know what to say no more,i hate this hybride sequencers.
>i want a simple analog sequencer,i want a smart quantizer not just
>the cromatic scale,i liked a lot the doep... desighn both
>of the triger sequencer and the quantizer chack it out.
>if the non MOAS would cost 400-500$ then how much the MOAS
>would cost 2000$,its crazy.
>for a guy like me how dont use MIDI at all i need lots
>of sequencers so do i gone end up with 5000$ of sequencer's ?
>thanx
>Gur Milstein
>At 06:27 PM 4/4/99 -0500, you wrote:
>>From: "Paul Schreiber" <synth1@...>
>>about $2.75ea.
>>LOVE assembly).
net,
>>blah blah blah.
>>Takers????
>>Paul S.
>>Mr. Mico
>>Have you visited our new web site?
>>http://www.onelist.com
>>Onelist: Helping to create Internet communities
>If you like orange and blue, then you will love our new web site!
>Onelist: Fostering connections and information exchange
1999-04-05 by JWBarlow@xxx.xxx
What a bunch we are!
Barlow can't justify the expense, but will tell you just how to build one.
Hendry doesn't know why he needs one.
Milstein wants one, but not the one Paul can build.
You GOTTA love this MOTM list (Moaners Of The Month).
Keep up the good work Paul!
Synth Peon
JB
I want it to be clear it is NOT a MAQ clone.
I have NO intent of any real-time patterm memory storage (ie the uP records
the pots
turning in real-time into memory for saving). And, this is NOT a MIDI
sequencer!
All sequencers are controlled by DIGITAL logic. They HAVE to be. Even the 25
year old Moog 960
uses digital (RTL!!) logic.
A sequencer is a digital shift register that gates analog voltages based on
a clock pulse.
I agree with Gur that if you overload a uP based system you will detect
lags/delays. So this is
EXACTLY why I want a simple, small sequencer.
Now there are 3 ways to make that digital control logic:
a) use 74HCxxx ICs
b) use a FGPA like an Altera or Xilinx
c) use a uP
The trouble with (a) and (b) is you cannot add features. The trouble with
(a) is it takes too many parts.
The trouble with (b) is that FPGAs tend to have a small lifetime then they
are replaced with bigger, faster
versions. And the development platforms are $$$ ($99 Cypress WARP is the
cheapest I've used).
The 8051 has been around for 15 years. The price is like $5/chip and 6
people make them. There are FREE
tools to write code. And, I can add features easily with a download
function.
A sequencer doesn't have a "sound". Rather, the point Gur is trying to make
is that Doepfer made too much stuff
with an underpowered uP and the end result is disappointing.
What I want is a smaller Moog 960 with a few MOTM-like additions. I don't
plan to spend 1000 hours on the code. Rather,
a sequencer that is easy to use and has a LOW parts count.
Plus, I want to post the source code on the web and have all you folks hack
it to death and develop your own
versions (Hack #1 is I can show you how to add your name in the display on
power-up)
I was "doing the numbers" and it is possible to get the kit closer to $300.
Date: Sunday, April 04, 1999 8:59 PM
>Hi Paul,John.
>sory i did not want it to sound angree,this are my points:
>i own a maq ver-3 for a long time ,i'm allso was very related to doepfer
>sequencer line for more then 4 years.
>i saw how he (doepfer) made so many mistake's with his sequencer's line.
>he ferst started with the maq ver-1 which was ok,but then he went for
>ver-2 and ver-3 which all were great by ther softwere desighn but
>they were sound bad and lots of bugs and the most importent
>this sequencers were hard to make music with be cause of ther non analog
>behaver.
>then he made the giant shaltwerk which was the memory of paterns
>that the maq was making,and was a stand alone triger sequencer,but agin
>it sound bad and was very hard to work with.
>i know so many guy's frome germany how bought this goodis and dont
>use them be cause of ther non analog nature.
>then ther was a big yell in germany for the real thing,doepfer sales
>was so down that he desided to finely make it.
>so he made a great desighn for a analog sequencer 8/2 with lots of analog
>goodis in side.
>and he made a great quantizer that makes work easy.
>now if you think about it then you realize that his analog stuff
>is competit with the digital he sale.
>now i have been thrugh this story once and i dont want to repet it
>agin,its a sad story.
>it would take time til guy's would undersand that the analog quality
>does not end up only in the sound but allso in the control.
>moog was end up be cause guy's think that digital sound is gone
>be beter,but many was wrong as analog come back big time.
>Paul i know that it do sound crazy to make all this function
>with analog IC but at the end it would be sound like a analog control.
>serge sequencer is most analog and it shure is sound analog.
>digital have delay time ,digital have bugs,and digital is cold compering
>to a true warm analog.
>ok you want to make a digital sequencer then make the MOAS a giant
>digital sequencer,but please dont make the small sequencer a digital one.
>agin i'm sory if i offend you i just want the MOTM kip bing the best
>analog modular system in the world(i realy think so).
>i dont want to see you going the same mistake doepfer did.
>and yes a uP can make it but a uP can all so make a fu.. nord modular
>and we all know how it sounds compering to analog.
>love you all
>Gur Milstein
>>voltage
>>way, under
to
>>both
You
>>can have
>>entry knob
is
>>a super Moog 960.
>>already written!
>>8051 can do in 3.
>>Paul S.
>>-----Original Message-----
>>>Hi.
>>>thanx
>>>Gur Milstein
>>>>about $2.75ea.
I
>>>>LOVE assembly).
2X8
>>net,
>>>>blah blah blah.
>>>>Takers????
>>>>Paul S.
>>>>Mr. Mico
1999-04-05 by J. Larry Hendry
I certainly did not take it as angry. Sounded more like "passionate" to me
which is a very good thing. Gur, I think everyone here appreciates your
comments. I know I am still trying to learn and I enjoy what you have to
say. The group will ALWAYS have different opinions. That is given. What
makes it great is that we can share those differences here like gentlemen
toward the common goal of the best MOTM modules Paul can make (and that we
can afford).
Now John, You may have just crossed the line here. <grin> Actually, I
resemble that remark, but I would like to clarify it somewhat. Maybe I
don't know "why" I need one, but I do know exactly what I want. I just ask
Paul and he tells me. See how simple that is. <grin> and John, I do
appreciate the humor. :)
> additions. I don't plan to spend 1000 hours on the code. Rather,
> you folks hack it to death and develop your own versions
> display on power-up)
$300.
> Paul S.
Count me in Paul. You will also have to teach me more about how to load
the source code modifications. I will buy one like that (or probably
whatever else you build since I still probably won't know why I need it
until it is in my rack for a couple of days).
Oh, and one last comment for John. Forget justifying the expense. I
certainly can't. But, here we are with opportunity and desire coming
together. Life is a Journey. Go for it !! <grin>
Larry Hendry
1999-04-05 by Gur Milstein
Hi.
thanx
Gur Milstein
>about $2.75ea.
>LOVE assembly).
>blah blah blah.
>Takers????
>Paul S.
>Mr. Mico
Hi Paul,John.
behaver.
goodis in side.
love you all
Gur Milstein
>voltage
>way, under
>both
>can have
>entry knob
>a super Moog 960.
>already written!
>8051 can do in 3.
>Paul S.
>>Hi.
>>thanx
>>Gur Milstein
>>>about $2.75ea.
>>>LOVE assembly).
>net,
>>>blah blah blah.
>>>Takers????
>>>Paul S.
>>>Mr. Mico
1999-04-05 by Thomas Hudson
You provide a sequencer with the ability to hack the software for
$300 and I am in.
Thomas
Hi Paul and list.
ok ,now how do you plan to make the stage select,if i want N step
to repeat twice do i need to enter it thrugh the LCD or is it
gone be thrugh a jack input ?
what i meen is do i need to progrem the sequencer to do my needs
by entering values or do i gone modulate it to do it ?
thanx
Gur Milstein
>the pots
>sequencer!
>year old Moog 960
>a clock pulse.
>a) use 74HCxxx ICs
>c) use a uP
>function.
>power-up)
>Paul S.
1999-04-07 by Dave Bradley
Count me in. I agree with Gur, however - you still want jacks for stage
gate outputs, and jacks for stage set also would be heavenly!
>power-up)
Dave in Deutschland, where there is no Dr. Pepper!
Daughter of MOAS
1999-08-13 by Dave Bradley
The Seq is NOT MOAS...rather a smaller, leaner version. MOAS may never be
built, I just like to daydream every now and
then!
The price of the kit varies as I add/subtract stuff: I'm still trying for
<$500 kit. It will be 1x16 or 2x8. 5U wide, 5U tall.
What the hell, it's a slow Friday...
Paul, how do you see arranging 16 pots on a 5 by 5 panel? As a 4x4 matrix?
What other panel elements would be there? LCD, 16 gate jax, mode switch,
clock jack, reset, rnd, up/down, etc. If it's programmable, you'd need input
devices for that also.
Also, how would you stack 2 together? You need at least a 24x1 in order to
reproduce Karn Evil 9...
The Instigator
RE: Daughter of MOAS
Cool, but how do you see arranging the pots on the panel?
Mr. Persistant
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Friday, August 13, 1999 3:58 PM
> Subject: Re: [motm] Daughter of MOAS
> Being the clever person I am, the SEQ has 99 pattern memory. So, you CHAIN
> patterns together.
> You can have a total sequence of 16 x 99 = 1584 notes. Now, you can
> real-time twiddle
> but 16 at once in this mode, but still.......
> Paul S.
1999-08-13 by Paul Schreiber
patterns together.
real-time twiddle
To: MOTM List <motm@onelist.com>
Date: Friday, August 13, 1999 3:41 PM
Subject: [motm] Daughter of MOAS
>From: "Dave Bradley" <daveb@...>
>then!
input
>The Instigator
>--------------------------- ONElist Sponsor ----------------------------
>GET WHAT YOU DESERVE! A NextCard Platinum VISA: DOUBLE Rewards points,
> NO annual fee & rates as low as 9.9 percent FIXED APR.
>Apply online today! http://www.onelist.com/ad/nextcard1
Girl #1: "Why do you keep dating that sadist?"
Girl #2: "Beats me!"
Date: Friday, August 13, 1999 4:04 PM
Subject: RE: [motm] Daughter of MOAS
>Mr. Persistant
CHAIN
>> patterns together.
>> real-time twiddle
>> Paul S.
>You can WIN $100 to Amazon.com by starting a new list at ONElist.
>Drawing is held each week through August 20. For details, go to
>http://www.onelist.com/info/onereachsplash3.html
Whoops! Sorry for the large attachment in glorious 24 bit color.
Dummy
> From: Dave Bradley [mailto:daveb@...]
> Sent: Friday, August 13, 1999 5:03 PM
> Since Paul refuses to give me any direction whatsoever on this,
> I'm forced to submit this proposed design to the list without his input...
> BWAHAHAHAHAHAHAHAHAHA
> Have a good weekend, everyone!
> Moe
1999-08-14 by J. Larry Hendry
to
> The Instigator
Dave,
NOW, you have my attention (Emmerson fan). :) LH
1999-08-14 by Tentochi
On the knob issue...
What about the possiblility of using the smaller Alcons???
Shemp the Flux Jockey
1999-08-14 by Paul Schreiber
Err...Alcos?
Date: Friday, August 13, 1999 8:49 PM
>From: "Tentochi" <tentochi@...>
>Create a list for FRIENDS & FAMILY...
>...and YOU can WIN $100 to Amazon.com. For details, go to
1999-08-16 by Gur Milstein
very nice Dave.
Paul i was wondering how the chin patern is gone work ?
thanx
Gur Milstein
At 08:43 16/08/99 -0500, you wrote:
>Well, that large attachment never arrived on the list, fortunately for
>everyone. It must have been filtered due to being too huge. Here's a
>glorious 16 color rendering of Daughter of MOAS, as rendered by Moe.
>Dave Bradley
1999-08-16 by Dave Bradley
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
> Sent: Friday, August 13, 1999 5:06 PM
> To: MOTM List
> Dummy
> his input...
> > Moe
> ONElist: your connection to like-minds and kindred spirits.
1999-08-16 by Paul Schreiber
Hmmm... I like the patch name!
I will try to fax Dave a more better layout (Dave send me fax # private).
The knobs will be smaller diameter (same basic shape) plus there will be
LEDs and an "date entry" rotary encoder + about 6 pushbuttons.
great desighn Paul,i like it all.
the weakness point of a system like this might be the editing of
the transit frome one patern(16 pots) to the other,as we want
to musicly relat this two.
i think this function must be the fastest and easy to use.
Paul how about making it a 4/4,as it usualy more easy to set
a 16 pots sequence by seting ferst 4 pots in a cycle mode and then
the next 4 pots.... and then chain this 4 mini sequences to reach a
16 step sequence ?
thanx
Gur Milstein
>There are 99 memorys (#1-99). The length is set to say 16. You twiddle the
>16 pots
>to the correct voltages, press <STORE>. (You 'alpha' in the location with
>the data entry knob).
>A <CHAIN> is another memory, that stores sequences of memory locations. A
><CHAIN> might be:
>1-2-45-3-74-1-70.
>In other words, it plays the notes in #1, followed by #2, followed by #45,
>etc.
>Of course, we could place a <HOLD> in the <CHAIN> until, say, a <GATE IN> is
>sensed.
>or a <HOLD/LOOP> that repeats the <CHAIN> over and over until <GATE IN> is
>active, then it proceeds.
1999-08-17 by J. Larry Hendry
> Here's a glorious 16 color rendering of Daughter
> Dave Bradley
OK Moe, I'll bite. I see the clever arrangement of jacks. Not subtle
enough to slip by those of us with two eyes. However, the arrangement of
the knobs is quite troublesome to me. They are not straight and I know
there is some sick twisted piece of logic behind what you have done
(engineers do nothing without a logical reason). So, share it with us and
tell us what's up.
The line between humor and just plain strange is getting gray.
Keep your eyes on the shiny object, you are getting sleepy.
Larry H.
1999-08-17 by JWBarlow@xxx.xxx
In a message dated 8/16/99 5:34:12 PM, gur_mil@... writes:
I think I can answer that -- your chin's gonna hit the floor when you hear
it!!!!
But seriously folks.....can you give us any details on the chaining, and if
one will be able to reassign a sequence of 1500+ notes on one bank to a
sequence of 750+ notes on two banks (and so on), or possibly, even have
simultaneous banks of different lengths.
With apologies to Gur,
John B.
1999-08-17 by Paul Schreiber
16 pots
<CHAIN> might be:
1-2-45-3-74-1-70.
etc.
sensed.
OR, a more bizarre <FORK>, which means if <GATE IN> is active *at that
time*, go on, else
branch to another <CHAIN>. Or a <HOLD CC>, which releases the <HOLD> if a
MIDI CC message is active........
The joys of the lowly microprocessor. Take *that*, lowy Moog 960.
> 16 pots
> <CHAIN> might be:
> 1-2-45-3-74-1-70.
#45,
> etc.
is
> sensed.
is
I REALLY like the sound of this type.
Stooge LH
> time*, go on, else
a
> Paul S.
> How do you enter ONElist�s WEEKLY DRAWING for $100?
> By joining the FRIENDS & FAMILY program. For details, go to
1999-08-17 by Doug Pearson
>From: "J. Larry Hendry" <jlarryh@...>
>the
>> 16 pots
>> <CHAIN> might be:
>> 1-2-45-3-74-1-70.
>#45,
>> etc.
>is
>> sensed.
>is
>Stooge LH
Me Too!!!
>> time*, go on, else
>a
What commands will there be?
<STORE>
<CHAIN>
<HOLD>
<HOLD/LOOP>
<FORK>
what else?
Will there be programmable algorithms for looped chains? Conditional
(<FORK>) chains within chains? I REALLY like this!
-Doug
ceres@...
P.S. Paul & Larry - did this message go through to the list? I seem to be
having trouble with Onelist ...
Daughter of MOAS
1999-08-22 by Andy Finch
The latest edition of SOS has just hit the streets, and it contains a
review of Analogue Solutions Concussor percussion modular/sequencer.
I haven't any experience of analogue sequencers yet, but they describe
in the review the fact that most sequencers RESET function resets the
sequencer to step 1, which means that the first note played will be step
2. The concussor resets to step 16, so step 1 will be the first note
played. Seems like common sense to me, but they say it is the only
sequencer that does it.
So, which step will Daughter of MOAS reset to???
BTW, SOS gave the Concussor a whopping 6 pages. I think MOTM fans would
be happy with that.
Cheers,
Andy.
1999-08-22 by Zsolt Homlokos
Andy Finch schrieb:
> From: Andy Finch <andyfinch@...>
> be happy with that.
> Cheers,
> Andy.
> ONElist users: YOU can win a $100 gift certificate to Amazon.com.
> Check out the FRIENDS & FAMILY program to find out how.
> <a href=" http://clickme.onelist.com/ad/Teaser112 ">Click Here</a>
correct me if i am wrong but i think this is a myth,
on my SQ10 theres nothing like this
