Re: MIDI->CV & MOTM-410
2000-02-10 by DAVEVOSH@aol.com
In a message dated 00-02-09 22:53:45 EST, you write:
<<  I find myself migrating toward the lower end of
 the range continually to get those best sweeping actions.  I would be very
 interested to hear how others are using and adjusting this module. >>
larry,
after all of three days with mine ( ! ), one thing i liked was setting the
filters up high and restricting the sweep range and using it to add some
"shimmer" to the high end of a moderately thick sounding drone-y sort of
patch on my brand D modular.
best,
dave
MIDI->CV & MOTM-410
2000-02-10 by J. Larry Hendry
> From: Frank Vanaman <fvanaman@...>
> Recently there was a comment about the PAiA MIDI2CV convertor being, er,
> well, about as good as one might expect for the price. (Larry H, I
> think?)
Yes, that was me.  Actually, the volt/octave version is not too bad.  For a
mono synth line, it is good enough.  The circuit board is about as good as
I have seen from PAiA.  Some of the discussion (over my head) on synth-DIY
has been critical of some of the circuit design.  But, I built it and it
works.   I have some issues with the V/Hz version.  The only required
modification (in my opinion) is replacement of the trim pot for V/Oct
calibration.  The kit has one of those VERY cheap 3/4 turn board mounted
trimmers.  I replaced it with a nice 10 turn pot that is tweakable from the
front of the cabinet.   Of course, there are plenty of other
"opportunities" for improvements.  But, all-in-all, I think it was worth
what it cost me.  The rack mount kit is cool if you want two.  Just be
aware that it seems to be 8 bit resolution, which seems to be OK for mono
lines, but I might be hesitant to use it in a poly situation.  However, the
output is more accurate that the resistor divider network in my MicroMoog.
BTW, I have been playing with my 410 at length tonight.  This type of
filter is not something I am real familiar with.  However, I do have an
understanding of how the controls function.  The question I have surrounds
the 3 frequency controls.  I find myself migrating toward the lower end of
Larry Hendry
2000-02-11 by JWBarlow@aol.com
In a message dated 2/9/2000 8:53:47 PM, jlarryh@... writes:
>er,
>> think?)
>a
>as
>the
>the
I have to agree with Larry on this. I have one as well (I hope to be able to
upgrade to a Kenton or Encore within the next couple of years) and it seems
like quite a reasonable deal for the money paid. I should mention that I'm
not a keyboard player, and MIDI is only a very small part of what I do. I
imagine if you get one and "grow out of it" you'll be able to find a place
for it in your system. While the 8 bit DAC will have certain idiosyncrasies
with regard to tuning, resistor divider keyboards (like my ARP, and OB-1)
also produce strange tonalities.
>of
Yeah, I typically run one filter at around two, the second around three and
the third around four. I think this is due to the filter being more likely to
get a positive CV which will raise the frequency, so you want to start pretty
low to begin with.
JB
