MOTM-650: load custom tunings?
2015-05-18 by Solar Marquardt
Archive for motm.
2015-06-01 by J.D. McEachin
>Greetings,I'm pretty sure all you have to do is send it a MIDI Tuning Standard
>Does anyone have the mysterious procedure for transferring custom
>tunings into the MOTM-650? Nothing in the manual, and only fragments
>of info come up on a Google search. Apparently it uses scala files,
>and in theory can be done, but I'd rather not stumble around in the
>dark if someone out there has done it and thus can share the
>procedure and any quirks (nobody on Muffs was able to answer, so
>trying this group). BTW, I'm on mac, but can borrow a PC if necessary.
2015-06-01 by Neil Bradley
> >dark if someone out there has done it and thus can share theAs the author of the microtuning code in the MOTM-650, I can confirm
> bulk dump. Several programs support it, including Scala:
> http://en.wikipedia.org/wiki/MIDI_Tuning_Standard .
2015-06-01 by Solar Marquardt
> As the author of the microtuning code in the MOTM-650, I can confirm Jeffrey's statement 100%.
> -->Neil
> C. Neil Bradley - Excessive process falsely elevates the incapable and ties
> the hands of the exceptional.
2015-06-02 by Neil Bradley
> One thing I find inconsistent; say you tune to just intonation, theBefore I delve into some details, I haven't touched the code in 13 years
> pitch wheel remains equal temperament semitones. If your playing style
> uses a lot of bends, that's a problem. Bending to some intervals will
> sound really bad, while others will be usable. Wouldn't it be possible
> for the 650 pitch wheel setting to reference the tuning table, and look
> up/down x number of ratios to find the correct stopping pitch?
> Mentioned this to Paul last week, he says that old processor is already
> pushed hard, but maybe Neil would know some fancy code that could do it?
