5U E560 Deflector Shield conversion
2014-07-18 by davebr@...
Archive for motm.
I just finished up doing a 5U conversion of the E560 Deflector Shield. It's basically the same as my E580 conversion but I took some photos and built a web page for it. Most of the conversion details are on my 580 page. This is a very nice module!
560 page
http://modularsynthesis.com/motm/e560/e560.htm
580 page
http://modularsynthesis.com/motm/e580/e580.htm
Dave
2014-07-18 by Richard Brewster
560 page
580 page
Dave
2014-07-18 by Paul Schreiber
No, I have like 60 boards here. So kits for either E560 or E580 (same pcb).
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Richard Brewster pugix@... [motm]
Sent: Friday, July 18, 2014 7:59 AM
To: MOTM List
Subject: Re: [motm] 5U E560 Deflector Shield conversion
These look great. I assume the DIY kits for these are no longer available. Paul?
Richard Brewster
http://pugix.com
560 page
580 page
Dave
2014-07-19 by Stephen Drake
> 560 page
> 580 page
> Dave
2014-08-23 by Richard Brewster
560 page
580 page
Dave
2014-08-24 by Stephen Drake
On Aug 23, 2014, at 5:52 PM, Richard Brewster pugix@... [motm] <motm-noreply@yahoogroups.com> wrote:
> I got the E560 and E580 DIY boards, and also FPE panels from Dave Brown's designs. I removed the switches and pots today. I want to use the pot mounting holes to mount the board to a bracket, so I don't have to drill holes in the corners of the PCB. Maybe I didn't get all the solder out of the pot mounting holes, because a 4-40 nylon screw doesn't quite fit through. If I removed all the solder would they fit? Or if I drilled them out to 1/8 inch, would that risk damaging the board?
> Thanks,
> Richard Brewster
> http://pugix.com
>> 560 page
>> 580 page
>> Dave
2014-09-06 by Andre Majorel
> I got the E560 and E580 DIY boards, and also FPE panels from DaveUS #4 is 2.84 mm, right ? You could use some M2.5 or M2 screws.
