At 2:16 PM 2/2/00, Paul Schreiber wrote:
>From: "Paul Schreiber" <synth1@...>
>Yes, the upcoming VC Lag will turn a GATE (NOT a TRIG) into a VC'd AR.
>But, there is alot of presicion stuff in there for VCO control voltages. A
>"dummied-down"
>version could easily make a dual AR with end-of-cycle re-trig and the
>ever-present
>Bradley LED.
>Paul S.
I think that both the VC Lag and and dual VC AD EG would be essential
modules, even with the overlap in functionality between them. One thing I
find is that you can never have enough envelopes.
________________________________________________________
Dave Trenkel : improv@... : www.peak.org/~improv/
"...there will come a day when you won't have to use
gasoline. You'd simply take a cassette and put it in
your car, let it run. You'd have to have the proper
type of music. Like you take two sticks, put 'em
together, make fire. You take some notes and rub 'em
together - dum, dum, dum, dum - fire, cosmic fire."
-Sun Ra
