MOTM 300 VCO help
2012-11-13 by gooboworks
Folks, I just finished building a MOTM 300 VCO. I have a problem. the EXP/LIN switch is not acting correctly. When I have a LFO control voltage in FM1 the oscillator appears to work fine when the switch is in the LIN position. When I switch it to EXP, the oscillator will does not react, the oscillator acts as if nothing is inserted into the FM1 jack.
I am an experienced builder and I have built MOTM 300's before. I know I can email Paul S. on this, but I wanted to hit the list first to see if anyone had any tips on where I might look for an issue.
Any thoughts on what might be the problem and where I can look?
Andy Miller
Andy Miller
