Archive for motm.
Euro panel dimensions...
2012-06-06 by Dave
Hi all!
Was wondering if anyone here has measurements for Euro front panels? I'd like to compliment Paul's new releases in Euro form, and need something with which to create an FPD template.
THANKS!
Dave
RE: [motm] Euro panel dimensions...
2012-06-07 by John L Rice
Hi Dave,
All the currently released Synth Tech Euro modules are 14HP wide.
From http://wiki.muffwiggler.com/wiki/Euro :
"The width of Euro modules is typically measured in "HP" (or "TE"); 1 TE/HP
is equivalent to 5.08mm, or 1/5 inch. So a 24 TE/HP width is 24/5, or 4.8".
In millimeters, it becomes 24 x 5.08, or 122mm."
Check out this resource too:
http://eurorackdb.com/node/h_module_list
John L Rice
http://www.facebook.com/ImJohnLRice
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Dave
> Sent: Wednesday, June 06, 2012 2:14 PM
> To: motm@yahoogroups.com
> Subject: [motm] Euro panel dimensions...
> Hi all!
like
which
> THANKS!
> Dave
Re: [motm] Euro panel dimensions...
2012-07-12 by Andre Majorel
Panel width k x .2" minus slop. Panel height 128.5 or 128.7 mm.
Thickness 2.5 mm or less. Screw holes every .2". Distance
between tapped strips 122.5 mm.
André Majorel http://www.teaser.fr/~amajorel/
2012-07-12 by Dave Garfield
Thank you, Andre.
Sent: Thursday, July 12, 2012 1:15 AM
Subject: Re: [motm] Euro panel dimensions...
