Archive for motm.
cabinet depth
Re: [motm] cabinet depth
2011-12-23 by David Moylan
These are SKB popup mixer cases. If you lay them flat you can lift the
modules up at an angle on ratcheting arms. They won't accommodate all
MOTM format modules. Definitely not something like the Blacet Time
Machine in MOTM format. Other than that limitation they're great.
On 12/23/11 7:58 AM, egroups@... wrote:
> Hi All,
> I just stumbled upon this image:
> http://en.wikipedia.org/wiki/File:Synthesis_Technology_MOTM.jpg
> To me the cabinet appears to be intriguingly shallow, anyone knows
> details about it?
> (maybe too shallow for some modules?
> Thanks, Michael.
2011-12-23 by evening1
My recollection is that Paul designed the module depths with this case in mind.
They are great, but they get heavy when loaded.
I've used nylon spacers to accommodate a deeper module - it's not pretty but it works.
They are great, but they get kinda heavy when loaded. Someone ( one of the stooges?) made aftermarket back panel covers as well.
jmw
2011-12-23 by groovyshaman
I have one of these SKB cases. Very handy for creating a small travel synth from
my bigger system. It also looks quite nice. However, the clasps to keep the
cover on are a little underdesigned, the cover can come undone rather easily.
Still, good bank for the buck. I was planning a panel to use up the remaining
space with mults, a stereo headphone amp and a power connection, but never got
around to it. Not sure but I thought someone else had created a panel for this
space.
George
----- Original Message ----
To: MOTM List <motm@yahoogroups.com>
Sent: Fri, December 23, 2011 7:58:55 AM
Subject: [motm] cabinet depth
Hi All,
To me the cabinet appears to be intriguingly shallow, anyone knows details about
it?
Thanks, Michael.
hear the colours of noise: http://blauwurf.at
http://soundcloud.com/noiseconformist
Yahoo! Groups Links
I can't believe Larry's website is still up! Still miss him.
George
To: motm@yahoogroups.com
Sent: Fri, December 23, 2011 12:35:19 PM
Subject: RE: [motm] cabinet depth
http://www.wiseguysynth.com/larry/skb/skb_back.htm
http://www.wiseguysynth.com/larry/SKB-power.htm
Doug
Yahoo! Groups Links
2011-12-23 by Jeff Laity
Yes, thank you to whoever is keeping this reference online!
George
Doug
Yahoo! Groups Links
2011-12-23 by Doug Wellington
I think it's Dave. And if he ever has to stop for some reason, I'll
take it over to keep it around...
Doug
2011-12-23 by John L Rice
If someone wants a heavier duty case (that weighs more of course!) and
doesn't need the popup functionality fixed position cases designed for live
mixers can work really well.
Here's a picture of a EWI case I'm using. I modified it so the rails are
parallel to the case bottom instead of being angled. It's considered a 12U
with extra depth. I changed the angle of the rail mounts and swapped in some
14U rails:
http://s275.photobucket.com/albums/jj304/JohnLRice/?action=view¤t=Port
These cases are a great value! Here's a link to the case on the seller's
site (Audiopile.net). It's only $120 plus shipping!
http://www.audiopile.net/products/Cases/Mixer_Cases/MXC-12L/MXC-12L_cutsheet
.shtml
They also have standard 10U and 12U mixer racks you could use as-is or
modify to be flat. (only $100 and $110 respectively)
http://www.audiopile.net/products/Cases/Mixer_Cases/MXC-008/MXC-008_cutsheet
.shtml
John L Rice
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> groovyshaman
> Sent: Friday, December 23, 2011 8:35 AM
> To: egroups@...; MOTM List
> Subject: Re: [motm] cabinet depth
synth
> from
easily.
remaining
got
> this
> space.
> George
> From: "egroups@..." <egroups@...>
> Hi All,
> about
> it?
> Thanks, Michael.
2011-12-23 by egroups@blauwurf.info
oh yes ... what a memory! :-(
You guys were fater than me, I was just about to point at this images,
I just didn't recognize the folded up cases.
Thanks a lot!
Happy Season! Michael.
> Regards,
> Doug
> George
nonconform? noiseconform: http://blauwurf.at
2011-12-24 by John L Rice
Wow, sorry for all the fractured links! :-(
I added the picture of my rack to the misc section in the group photos.
For the EWI cases at AudioPile go here and select the Mixer link:
http://www.audiopile.net/products/Cases/Case_products_page.shtml
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of John
L
> Rice
> Sent: Friday, December 23, 2011 11:16 AM
> To: 'MOTM List'
live
some
> 14U rails:
> .shtml
> .shtml
> John L Rice
> > groovyshaman
> synth
> > from
keep
> the
> easily.
> remaining
never
> got
for
> > this
> > space.
> > George
> > Hi All,
details
> > about
> > it?
> > Thanks, Michael.
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Re: cabinet depth
2011-12-25 by IvanCU2
If anyone is interested in this type of case I have two of the Gator Cases G-MIX-12 PU that are brand new in their boxes that I'd like to sell. These are an inch deeper than the SKB cases.
http://gatorcases.com/Default.aspx?Section=Products&Page=Details&CategoryID=4534&CatalogID=9149
