FS: MOTM and MOTM format stuff
2011-05-19 by fourthreetwohz
First personal e-mail reply for a particular item gets it. I will hold items for 48 hours for you if you cannot pay immediately, after that time I will go onto the next person.
Everything is guaranteed to work on arrival unless noted. No mounting screws or power cables, sorry. Some stuff in here needs repair or has cosmetic defects. I have noted any issues that I know about.
Sorry for the dust, but it's been sitting around for awhile. I'll do my best to clean things up before shipping.
Prices are plus shipping and my obsessively good packaging. I will ship worldwide if you want to pay for it. I only accept PayPal payments for this stuff.
MOTM-410 Triple Resonant filter - $250
Has signal output boost switch installed on panel.
http://denonville.com/synthsale/triple1.jpg
http://denonville.com/synthsale/triple2.jpg
Oakley OMS-410 Triple Resonant Filter Aid - $100
Comes with connectors to connect up to the MOTM-410, but they need to be soldered in.
http://denonville.com/synthsale/oms1.jpg
http://denonville.com/synthsale/oms2.jpg
Prototype Larry hendry MOTM format dual pedal interface - $50
Works with Yamaha volume pedals, would have to be rewired to use with others.
http://denonville.com/synthsale/pedal1.jpg
http://denonville.com/synthsale/pedal2.jpg
Blacet Dual Filter in MOTM format panel - $100
Like an adjustable fixed filter. High, low, and bandpass modes.
http://denonville.com/synthsale/dual1.jpg
http://denonville.com/synthsale/dual2.jpg
Oakley Issue 2 midiDAC MIDI to CV converter in MOTM format - $100
Gate LED was always flaky. I think it needs a new one because the leads going to it have suffered metal fatigue. Another jack needs to be wired up. I also mis-placed some of the jacks in the wrong holes, so that will need to be sorted out as well. Works fine otherwise. MOTM knobs will be put on prior to shipping.
http://denonville.com/synthsale/midi1.jpg
http://denonville.com/synthsale/midi2.jpg
Oakley custom MOTM format Dual Sample and Slew module - $100
Two in one 1U module.
http://denonville.com/synthsale/sh1.jpg
http://denonville.com/synthsale/sh2.jpg
MOTM format mutliples - Qty. 2 - $30 ea.
Custom made.
http://denonville.com/synthsale/mult.jpg
Bridechamber Oakley Sample/Slew - Qty. 2 = $15 ea.
http://denonville.com/synthsale/slewpanels.jpg
Bridechamber MOTM module mounting rails (used) - Qty. 2 pair - $12 ea. pair
Custom made.
