FS: Mattson 5U CV Mixer & Blacet VCA
2011-03-12 by Ritchie
Blacet FRAC Dual Linear VCA
(pots a little scratchy, but sounds GREAT!)
$79.00
MOTM-Mattson voltage controlled 4 channel mixer with 0-5VDC control voltage inputs. The CV inputs are cascaded from channel 1 to channel 4 to allow for one CV to control all four channels if desired. Another CV patched into another channel will interrupt the previously cascaded signal to that channel and will control all subsequent channels. An internal 5VDC bias is "normalled" to the CV inputs to allow the module to be used as a manual mixer if no CV inputs are patched into the "Control in" input. The factory calibration is 1:1 input signal to output signal.
Much higher channel gain can be set if desired.
Both MOTM & .com power connections!!
(scratch at upper left....)
$145.00
Pics:
http://www.muffwiggler.com/forum/userpix/2250_matt_1.jpg
http://www.muffwiggler.com/forum/userpix/2250_matt2_1.jpg
$79.00
$145.00
Pics:
