2011 evil plans
2011 evil plans
2011-01-18 by Paul Schreiber
Back from NAMM (had fun, but tiring) and have started thinking about what to
do for 5U MOTM furture plans. This is independent from shipping current
backlog, I'm speaking of 5U plans in general.
These are not in order of execution. I'm not committing to any time per se.
Comments welcome, that's why I'm posting. If you agree or disagree, let me
know.
MOTM-650 replacement
The current MOTM-650 is not going to be offered, except under special
conditions. I don't have jacks for it until the end of March (then, I'll
have 800 extra...oh boy....). I might have parts to make 2 or 3 more than
currently ordered, but not really going to focus there. Rather, I spent most
of today looking at current ICs/processors/displays/etc and have decided
that I can 'start over' and still offer a 4ch MIDI-CV with some reduction in
the firmware *features* and not increase the price. It will still be 2U
wide, but be slightly different in appearance.
a) the LCD is going to a 2 x 12 versus current 2 x 8 (cheaper, oddly enough)
b) instead of the 4-button interface, the up/down buttons are replaced with
a rotary encoder
c) CLK IN goes away
As far as major features, that is not decided (I am *really* interested in
hearing from users what features/modes are not used/rarely used). So far:
a) no tuning tables, but there is a volts/Hz mode (so, there are 2 tuning
tables I suppose).
b) simplify the # of options for things like voltage range on AUX
c) CCs will all be implemented as expected
d) not yet sure if keeping arpeggiator #2.
We are looking hard at having firmware updates via SD card. The SD card
socket is in the rear (pcb mounted) to you would power down, stick in the
card, power up and hit a button. Uses standard FAT file system, so no more
PC/Mac issues. In order to do this "properly", we have to get the FAT system
in the CPU to < 8K (which is the boot-block protected area). We should know
this in a few weeks.
I am not doing all this work soley for the MOTM-650 replacement, I want to
offer it in other formats as well.
Offering current Euro modules in 'true' 5U
In terms of time-to-market and to spur sales, I will be seriouly looking
into having the 4 Euro modules (E340 Cloud, E350 Morphing Terrarium, E560
Deflector Shield and E580 Resampling Mini-Delay) redesigned and re-layed out
for 2U wide 5U MOTM/.com MU (dual power connectors, heck toss in Modcan B as
well). This is not a "repanel" but a true, dedicated set of new panels and
pc boards. I would put all 4 designs up on a pc fab panel (so the SMT
machine stuffs 1 of each per pass). The current '520 panels would be
scrapped, and the 521 CGX Expander is a memory. This is a decision that
immediately will "cost" me $7000 (what I paid 5 years ago for the panels +
parts). But the reality is my time is limited more now than ever (and is
about to get even tighter due to day job pressures) and I can do this work
for 4 modules in the same time it would take to do *just* the FPGA-based
'520 (not even looking at the '521).
Yes, the '520 Cloud had more bells and whistles BUT the Euro Cloud has
gotten me many rave reviews by the users. And, it will be $100 or so cheaper
than the '520.
In this manner, I can have 4 new and 1 re-designed modules in 5U this year.
There will be NO LONG WAITS as the modules take < 12 minutes to make,
program and ca (what is amazing to an old fart like me that used to watch
Data I/O 29Bs take 32 MINUTES to program a 64K EPROM, is that these new
FLASH CPUS program 128K in under 4 seconds.). The SMT machine can happily,
in 1 4-hour run, make 100 of *each* module's pc board. The jacks will be
vertical mounted and wave soldered in 1 pass. All I do is screw 2 boards
into the panel, pop in 1 short ribbon cable and I'm done.
And, as a last thought.....
MOTM-101 Replacement
I could take some of the parts left from the '520 and make a 1U wide
noise/Cascaded S&H module. The '101 is tedious to make, a low seller and has
hard-to-get parts. The new '102 has zero-droop S&H, "correct" clocking edges
and maybe even a quantizer thrown in for fun.
Well, this is what I'm thinking about. Thoughts? Comments?
Re: [motm] 2011 evil plans
2011-01-18 by p.hendricks
any ETA for things sent for repair in 2009?
thanks!
> know.
> a rotary encoder
> c) CLK IN goes away
> tables I suppose).
> than the '520.
> Paul S.
2011-01-18 by Thomas White
Yay! Woo hoo! I hope to see these ideas happen. Fingers crossed Paul. Placed my 1st order about 11 years ago now. Still going!
Thomas White
Natural Rhythm Music
know.
a rotary encoder
c) CLK IN goes away
tables I suppose).
than the '520.
Re : [motm] 2011 evil plans
2011-01-18 by ROV PILOT
those are exxxcellent news, making my day. I know have a reason for which I sweat offshore...
Back to work, the hardest point will be to stay focused and not start to patch in my head...
De : Paul Schreiber <synth1@...>
À : MOTM List <motm@yahoogroups.com>
Envoyé le : Mar 18 janvier 2011, 6h 58min 24s
Objet : [motm] 2011 evil plans
know.
a rotary encoder
c) CLK IN goes away
tables I suppose).
than the '520.
2011-01-18 by Ben Stuyts
> know.
- Midi over DIN, but also over USB so you can plug it into your laptop w/o any additional interface.
- Polyphonic aftertouch support. (Currently using a Gem S2 which has poly-AT as controller for my modular.)
> tables I suppose).
Tuning tables would be nice to have.
I'd loose that and just use the USB port for upgrades.
Kind regards,
Ben
2011-01-18 by Richard Brewster
Paul,
It's great to hear forward motion on the 5U front! But if you keep
putting out DIY kits for the 4 Euro format modules (I have one E340 DIY
kit on order), I'll probably have built all of those before the 5U
formats come out.
I've been interested in the MOTM-102 S&H ever since you mentioned it
some time ago. It doesn't need to have noise. Everyone wants more
sample and holds than noise sources. So don't forgo other good S&H
features for a noise output.
Richard Brewster
http://pugix.com
> know.
> a rotary encoder
> c) CLK IN goes away
> tables I suppose).
> in the CPU to< 8K (which is the boot-block protected area). We should know
> than the '520.
> There will be NO LONG WAITS as the modules take< 12 minutes to make,
> Paul S.
Re - USB upgrades.
Now back to Mac & PC support + additionasl cost.
SD card support is a $0.68 connector :)
> formats come out.
Only for E340/E350, and then I sell just a handful.
It's "free" and doesn't take up much space (1 jack + 1 knob).
RE: [motm] 2011 evil plans
2011-01-18 by carl schmidt
Just to say, I couldn't be happier that the euro modules are getting a proper 5U issue! That's always been the nicest format around ;)
2011-01-18 by Jeff Laity
It was great talking to you at NAMM. Thanks for listening to me rant about 5U development. I think you will see more life in the format if there's more than one new module and one website update every 5 years!!
Of your list, the 1u noise/S&H module is my top pick. I would buy that today. I'm also interested in 'true' 5u ports of the new digital modules, especially the Morphing Terrarium and the Frequency Shifter thingy.
I have a 650 now. I mostly use it as a one-voice MIDI/CV controller, occasionally using one arpeggiator. I would suggest as many possible MIDI CC to CV options as possible, I can never have enough of those. It is very easy to draw or play a controller in my sequencer to use as a repeatable CV source.
Thanks for showing the 5u crowd some love. :)
know.
a rotary encoder
c) CLK IN goes away
tables I suppose).
than the '520.
NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary." This e-mail may be viewed and used only by the person to whom it has been sent and his/her employer solely for the express purpose for which it has been disclosed and only in accordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity.
2011-01-18 by George Kisslak
Paul, it's great to hear you have renewed energy ready to put into the 5U
MOTM format. Although I did most of my ordering back in 2001 thru 2004,
I've always been up for any new modules you've had in the MOTM 5U format.
There have been many discussions over the last 10 years of interesting
modules that unfortunately have never come to fruition, in fact back in 2009
I posted a giant list of them here. As for my top 5 interests:
MOTM-130 Dual Pan/Fade VCA (please??)
MOTM-520/521 Cloud Gen (ordered back in 2004 but you canceled on 6/17/2006)
MOTM-102 Noise/ASR (with a quantizer sounds perfect)
E350 Morphing Terrarium 5U conversion
MOTM-475 Crow's GX-1 BP-VCF
I definitely look forward to the opportunity to order any new MOTM 5U
modules - I just hope you have time to make them happen at some point!
-George
> know.
> a rotary encoder
> c) CLK IN goes away
> tables I suppose).
> than the '520.
> Paul S.
MOTM Order page
2011-01-20 by Scott E.
Paul,
Will you be having front panels for the 800 EG back on the order page
any time soon?
Scott E.
