FS: US: MOTM NEW MFOS VCF's $200 each!!!
2011-01-12 by Logan
built 2 of each of these because I have OCD when it comes to building modules... I build in pairs. :) I'm building 2 MegaPercussiveSynths in MOTM format and i need to make room in my rack. So 1 of each are available. anyways, I Finished these up a couple weeks back and put them in my rack to test and they've sat there since. So they're basically "Brand New" professionally assembled modules. I'll include rack screws and dc cables w/ them. (1) State Variable VCF 12dB/Octave With VC Resonance: $200 + $15 Priority Shipping * State Variable VCF 12dB/Octave With VC Resonance * Simultaneous High-Pass, Low-Pass and Band Pass Filter outputs. * Log Response to Control Voltage (1V/Oct Tunable) * Sine Wave Oscillator at full resonance * Power Supply Range +/-9V up to +/-15V * Voltage Controlled Resonance (Linear control) (1) VCF Four Pole 24dB/Oct With VC Resonance:$200+$15 Prioriity Shipping * Four Pole 24dB Per Octave Low Pass Filter * Log Response to Control Voltage (1V/Oct Tunable) * Makes A Nice Sine Wave Oscillator * Power Supply Range +/-9V up to +/-15V * Voltage Controlled Cut-Off Frequency * Voltage Controlled Resonance Here is a picture of the two modules: http://farm6.static.flickr.com/5088/5315887511_79cb6406d9_z.jpg here's a video of me using the a wogglebug running into the vcLowPassFilter. My delay pedals battery was about to die which is why it sounds like it's running through an overdrive. not to mention the hot signal running into the pedal. Woggle, Filter and delay are the only things used. http://vimeo.com/18333070 $200 each or buy both for $375 + shipping!!! Drop me an email if interested: logan [at] lowgain-audio [dot] com
