Index last updated: 2026-03-30 17:37 UTC
Steam Powered Sequencer
2010-08-31 by Paul Bower
hello all,
i've been quiet for a while, i recently felt compelled to buy a steam engine on ebay, and then hatched a plan:
you'll recognise the MOTM120 sequence with a little variation courtesy of some CGS modules
the dynamo is just regulating the tempo of a MOTM320 LFO via it's V/Oct input
i did spend most of the bank holiday monday building a steam powered pulse generator (add a rotating disc and a pair of commutators) but the steam engine wasn't powerful enough to power my clunky transmission (bits of old tape machines, the shaft from a coffee percolator, bits of hard disk and a hairdryer)
maybe next weekend :-)
cheers
paul
Re: [motm] Steam Powered Sequencer
2010-08-31 by Richard Brewster
Very interesting, Paul. What's the fuel source for the steam engine? Could see the flame in there. Was it slowing down at the end because the engine was running down? Now you need to add voltage control to the steam engine to control the throttle! And make a 5U panel for it :)
Richard Brewster
http://pugix.com
On 8/31/10 8:24 AM, Paul Bower wrote:
hello all,
cheers
paul
RE: [motm] Steam Powered Sequencer
2010-09-01 by Paul Wagorn
Maybe you can have it run a steam powered oscillator:
http://www.synthgear.com/2010/strange-weird/steam-powered-synthesizer/
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Richard Brewster
Sent: August-31-10 3:28 PM
To: Paul Bower
Cc: MOTM List
Subject: Re: [motm] Steam Powered Sequencer
Richard Brewster
http://pugix.com
hello all,
cheers
paul
2010-09-01 by Paul Bower
hello there,
it's an old 1920's model - so runs on meths (!!!) which is handy
the soundtrack isn't sync-ed to the picture - this was just my first attempt, the entire track is around 10 minutes long, the first six minutes are attempts at getting the transmission running :-)
no throttle on this thing - it's either running or it's stalled - but i guess with gearing i could adjust the rotational speed of the dynamo
not sure about a 5U panel - when my carpentry skills improve, i've a MFOS that's screaming out for another case
cheers
paul
Richard Brewster
http://pugix.com
hello all,
cheers
paul
hmm....
i've got a hetrodyne bat detector somewhere that's great for picking up anything except actual bats
there's also a steam powered tape echo on the cards, just need to find some old electronics to scavenge
To: Paul Bower
Cc: MOTM List
Richard Brewster
http://pugix.com
hello all,
cheers
paul
